can the F250 entire front end fit a 2005 model?
If you changed the entire front end along with brackets for lights and whatnot, it should all fit. The older trucks had two bulbs for the front turn signals (one main and one corner), whereas I believe the 08-10 uses only one main bulb in the turn signal. At any rate it would be expensive.
ericconn
01-21-2014 07:38 AM
Fordtrulover
1999 to 2016 Super Duty
17
07-18-2010 09:15 PM
