Recommended readings - Temperature and Pressure
iN terms of the pressure gauge on the dash i did a mod like this on my old 95 Explorer where i insatlled a real pressure sending unit ment for an old 80's mustang into the factory spot where the pressure switch was and plugged it into the factory wire. Then had to remove the dash and remove a resistor behind the gauge and carefully solider a jumper in instead. It worked great. 2 months later crashed the truck :-(
i am interested to know if anyone has done this on the super duty yet. i have not had my dash apart to even look yet.
Thanks
TSB 09-24-3 adds a few items to consider with regards to readings:
Wrench light comes on and defuel at 28.6 psig boost (I am told this specific value is from the PC/ED manual).
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when the PCM VPWR PIDS is below 10.25V for 60 seconds or below 9V for 4 seconds.
This TSB is for 2005-2007 engines (and 2008 - 2010 E series).
Maybe Matt or Eric will chime in if they see this. I would like to know as I have tunes from both. Matt said on his street + to see where the boost was and if not over 30 to go to ++. I have been up to 28 and am thinking about leaving it. I do have studs but just not sure and now with what you said about the defuel I would love and answer
This seems to be true of all the sensors, except for the oil pressure, which is really just a switch. Ford even calls it a switch.
#28
#30
If you're using the built-in MAP gauge reading, subtract 15 from it to get "close" to what you're running for boost.
MAP is an absolute pressure reading; you can subtract atmospheric (14.7 psi @ sea level) to get boost. Of course that will change if you go up in altitude, but it's quick-and-dirty.
-blaine
-blaine
