EGR Cooler / Oil Cooler Replacement
Ok, I have extensively read posts on this forum regarding all the pros/cons of EGR coolers. I have a leaking EGR cooler and need to replace it. I do most of my mechanic work myself, but I have a question. Do I need to replace the oil cooler at this time also? I am short on funds so if not necesary I don't want to, however I don't want the new EGR cooler to fail quickly because I didn't. I have a Dasdaq and my EOT and ECT run well below 15 degrees difference. Only when I am pulling my travel trailer hard at 70 mph on hard grades or against a strong headwind do I get up to the 15 degree difference and I have had a slightly larger difference, but it doesn't last long. Most of what I have read says that if the oil cooler is plugged or restricted the difference will be more than the 15 deg. Any thoughts or suggestions would be much appreciated. Thanks - David
I would do both.
I would also use this EGR cooler over the stock one
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0
I would do both.
I can see where they might not be as efficient since there isn't as much area for heat transfer...I guess the only question in that regard is how much if any difference it makes in performance/longevity. It's been a little over 15k miles since mine was installed, which is nothing as far as longevity goes, but I've noticed no difference in performance.
Have you had any EGR valve issues before and/or after the BPD cooler was installed?
Something in me says the mildy warmer air might reduce the sticking of the soot to the EGR valve. But what do I really know
Zero issues Newman....never had a problem with a dirty EGR before or since, except for when the cooler went South.
There is a great thread here where bismic lists the temperature values he has derived from a combination of Ford specs and people's experiences. I think my experience is generally in that range...
https://www.ford-trucks.com/forums/971345-temps.html
