truck shakes violently need help narrowing this down
Old 07-15-2010, 08:53 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
Well I would get those tires checked for the balance before tearing anything apart lol. That is the cheapest thing to do first.
  #62
Old 07-15-2010, 09:45 PM
powerstroker100's Avatar
powerstroker100
powerstroker100 is offline
well at some point I need to replace those joints how expensive do you think those will be? I want everything on the front end to be top for plowing this year, I'm hoping for atleast 6 residential contracts but no commercial and it snows quite often up here
  #63
Old 07-15-2010, 10:01 PM
kenpobuck's Avatar
kenpobuck
i would check prices at a good parts store. You can do it on the cheap from some place like autozone but it will not last. I think I payed like $150 for everything from side to side. I didn't do the ball joints tho. The alignment I can't remeber what it cost.
  #64
Old 07-15-2010, 10:06 PM
CHELLIE's Avatar
CHELLIE
CHELLIE is offline
Originally Posted by powerstroker100
yes I checked did the test where you lift both front tires and move the wheel in and out and side to side, it passed there is no slack what so ever, my driveshaft doesnt seem to be bent(but thats only from me staring at it) no weights apear to have fallen off, I don't know about it being timed last, I know that on my passenger outer tire it doesnt have a wheel weight on it
I Have never seen a tire perfectly balanced that did not need a tire weight have that wheel checked for balance
  #65
Old 07-15-2010, 10:08 PM
redmanplumber's Avatar
redmanplumber
redmanplumber is offline
last time i had a shake like that, a belt had shiffted or broke on a tire
  #66
Old 07-15-2010, 10:23 PM
powerstroker100
yikes 150 big ones plus the alignment after and now wheel balancing this truck is here to bleed me, starting to wish I had my powerstroke back, huh who said that? lol
  #67
Old 07-15-2010, 10:29 PM
kenpobuck's Avatar
kenpobuck
You better hope your truck don't hear that lol!
  #68
Old 07-15-2010, 10:49 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
foul language is inappropriate in this forum!
-Enjoy
fh : )_~
  #69
Old 07-15-2010, 10:51 PM
Rick Wallace's Avatar
Rick Wallace
Rick Wallace is offline
-Enjoy
fh : )_~
YEA What he said,,, did it stop shakin???
  #70
Old 07-15-2010, 11:29 PM
powerstroker100
lol sorry guys that was the worst in me coming out and nope the shake didnt stop rick, going to have the truck balanced and we'll see what happens after, so in general do tie rod ends and the track bar make the truck shake if its broken?
  #71
Old 07-15-2010, 11:36 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
you may have just lost some weights off the rims when you got stuck in the mud.....hopefully.
i wouldn't jump to conclusions on your front end being shot.you'd feel it in the wheel and turning.besides shaking doesn't really happen as they ware.
sounds like unbalanced tires or a broken belt.
do you feel it in the steering wheel or in the seat of your pants?
  #72
Old 07-15-2010, 11:42 PM
CHELLIE's Avatar
CHELLIE
CHELLIE is offline
you can jack up the front of the truck up a little so the wheels are 1" off the ground, grab one of the wheels and move it from right to left, check for play in all the tie rod ends, drag link, idler arm, etc. when moving the wheel back and forth, have someone move the tire for you better yet, there should be no movement, no play at all at those areas, if there is, they are worn out and need to be replaced.
  #73
Old 07-15-2010, 11:54 PM
powerstroker100
yeah but why are the rubber boots exploded? the one is all torn the other two blew up and the strange thing is I did the test two days ago, moving front wheels in out and left to right and there was no play, theres only about 3" of slack in the steering wheel, and I feel the shake in the seat AND in the steering wheel, I was on the on ramp today doing 45mph and turning left and I felt it start shaking alot worse than normal in the steering wheel but as soon as the truck leveled out the shaking cleared up but was still there
  #74
Old 07-16-2010, 12:01 AM
Rick Wallace
Have you checked your transmission mount???If its loose or broke maybe?? Just a thought.......
  #75
Old 07-16-2010, 12:05 AM
poocher pup's Avatar
poocher pup
poocher pup is offline
the rubber caps blow when the rubber ages and if to much grease is added. if you think the joints are good you can buy just the caps and replace them
Quick Reply: truck shakes violently need help narrowing this down
