Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-13-2010, 03:45 PM
rkatk rkatk is offline
Garage is empty, add now
rkatk is starting off with a positive reputation.
Econoline Pickup Transmission
I have a 1965 Econoline pickup with the 170 ci engine. What are the differences in the 3 speed transmissions from year to year and are they all enterchangable? I know the rear transmission mount has an early and late design.
Thanks
  #2 (permalink)
Old 07-13-2010, 05:25 PM
Transmission
Lets try a different question.
Should my 65 Econoline pickup have the early Borg Warner T-10 or the 3.03 Ford Toploader 3 speed transmission? I understand the Toploader was introduced in 64, but was it offered on the Econoline Pickup
Thanks
  #3 (permalink)
Old 07-14-2010, 09:48 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
What I learned was that the internals of the 65 and newer are suspose to be the same as a regular truck tranny. So they can interchange the parts. Also the housing the same. Just the tail shaft is shorter and its housing. So a trucks trans can be bolted on with a change of the tail shafts. Trucks ones are longer.
64 and down the internals can be changed from the Falcon cars or even as I did mine a 59 Ford car. Again the tailshaft has to be changed to fit the Econoline.
The earlier ones had car trans and the 65 newer had more truck trans. That is what I have experienced so far.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
Tags
1961, 19611967, 64, borg, difference, econoline, ford, mount, mounts, pickup, t10, trans, transmision, transmission, warner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
