Which 8 Lug Wheels will fit a Dent?
Old 09-09-2011, 06:07 PM
highboy1974's Avatar
highboy1974
highboy1974 is offline
whats the tallest rim ya can use? 18", 17" ??? I am running 16.5 on my 74 highboy f250 now
Old 09-09-2011, 07:33 PM
jwmayfield's Avatar
jwmayfield
jwmayfield is offline
My truck has turbine 8 lugs on it. any ideas how to clean them up they are kind of oxidised
Old 09-09-2011, 10:29 PM
supercabfreak's Avatar
supercabfreak
supercabfreak is offline
im running a set of doge rims on my truck and evidently someone ground out the center to fit over the dana 70 rear hubs.............i figured this out the hard way when i had a blow out and the spare didnt fit
Old 03-21-2012, 02:26 PM
jbouknight's Avatar
jbouknight
jbouknight is offline
I was going to go to 16" factory wheels on mine but the hubs too large for the center and, more importantly, the brakes and parts are to large. They don't fit inside 16" dually wheels. It had 16.5's on it at purchase.
Old 03-22-2012, 04:43 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,313 Likes on 2,463 Posts
Originally Posted by Kalve
So I need to ask an see if the wheels are 8x6.5 bolt pattern an if so they will fit correct? An how do you know if they are the 8x6.5 bolt pattern?
Yes and look for 8 lug bolt holes and measure from the outside edge of one hole across to the outside edge of the other, 6 1/2" is what you are looking for.
Old 03-22-2012, 04:47 AM
77&79F250's Avatar
77&79F250
Dually rims use a adapter/hub spacer on the front and rear.....I believe.
16's will fit with a little off set to clear the brakes or some folks grind a little caliper edge off.
E.j. May
11-01-2021 11:58 AM
flyingtexan
1999 to 2016 Super Duty
24
06-10-2016 05:29 PM
Comanche1Star
10-05-2010 01:11 PM
cesspool
06-10-2010 10:23 AM
250LDwelder
1997 - 2003 F150
09-26-2004 12:07 PM
Quick Reply: Which 8 Lug Wheels will fit a Dent?
