Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-12-2010, 10:04 AM
gpfarrell gpfarrell is offline
Garage is empty, add now
gpfarrell is starting off with a positive reputation.
Earlier wheels?
Can I use wheels from an '05 Navigator on my '07 Navi L?
I know I'll need to add TPMS sensors to them.
My Navi has 20"s and I'd like to step down to 18"s for winter wheels & tires. I found a set of earlier wheels but can't find a straight answer on swapping them.
Does anybody know about some of the wheels have 12mm holes and some having 14mm holes?
Thanks!
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #2 (permalink)
Old 07-12-2010, 12:15 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
The brakes changed and take up a lot of space. I don't think they will fit but I would check it out.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 11-15-2010, 07:49 PM
I won't guarantee it, but after checking lots of places it seems any late model Ford 6-bolt 17", 18" or 20" wheel should fit. Lots of Expys come standard with 17" wheels, as do lots of F150s.
2004 seems to be a year that shows up often for interchanges... but if it's its a recent 6-bolt Ford wheel it should be fine.
__________________
  #4 (permalink)
Old 11-16-2010, 12:27 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
yes
2003+ Expy/Navi 100% interchange
2004+ F-150/Mark Lt 100% interchange
be careful with some of the 2005-2006 Navi rims. There was a run where the inner hub diameter was a hair too small. Several F-150 guys got their Navi rims stuck on the rear hubs and had to beat the rims off.
otherwise, the rims between the years listed above interchange 100% between Expy/Navi/F-150/Mark Lt.
btw, 17" is the smallest rim you can use. The brake caliper won't let a 16" rim clear without some serious offset and/or shaving. So any OEM 17/18/20/22/23" rim will work fine for you.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
