North Carolina Chapter Join Chapter, Leader:Benztechnc
dismantling
Old 07-12-2010, 08:42 PM
dlocklear11's Avatar
dlocklear11
dlocklear11 is offline
dismantling
I got a 460 out of a lincoln bout a 75 model and wanted to know if its possible to strip off the a/c compressor and the power steering and it still be fine, also my basic question is can i use the same ignition system that is currently on my 68 f100 and fire it up and it run right it is carburated, but was wondering if anyone had done this and what types of issues they ran into, i have the mounts and perches and towers and all to sit it in problem is i want it to run when it does
Old 07-13-2010, 11:07 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
It should be fine without the a/c and p/s.
Not sure on the ignition system. If they both run the same kind it should work, but I dont' know if they are both points style or newer... Depends on the distributor mainly.
Is your '68 a 460 also?
jmm137
2004 - 2008 F150
15
12-29-2010 12:33 AM
54truck
12-09-2009 12:35 PM
Highmark18
16
02-13-2006 05:38 AM
thenubsterman
06-17-2005 06:54 PM
redneck1877
09-07-2004 09:22 PM
Quick Reply: dismantling
