SES light will NOT go off
Hey guys, long story short version:
2002 f-150, 4.2L v-6, 5 speed.
for a year now the SES light has been on.
Started out with both banks lean, now only bank 1 lean (again).
I'm not able to provide the specific codes at this time.
I'm a certified tech so I feel kinda stupid by this point.
Multiple scans, Multiples parts thrown it's way:
3 DPFE sensors
EGR Valve
3 MAF's
2 complete sets of O2 sensors (2 each bank)
Plenum spacer with updated isolator bolts (twice)
New plugs (wires were good at the time)
Of course new air filter (on regular basis), new fuel filter(s), oil changes every 3k, Trans and differential serviced regularly.
Fuel injectors test fine, no noticeable running problems (sometimes a little bit rough at first start up for about 2 minutes).
Have checked for vac leaks throughout (smoke machine, and the old reliable carb cleaner near possible leak locations).
It's also had a couple sea foam "treatments".
AND: it makes no difference how many times I reset the code(s), they keep coming back.
I'm ready to drive this thing in to the lake.
have NOT replaced the cats, coil, plug wires or fuel injectors.
Any ideas or suggestions would be appreciated, I have to get this thing inspected next month and the light cannot be on (or reset within 2 cycles).
3 DPFE sensors
EGR Valve
3 MAF's
3 DPFE sensors
EGR Valve
3 MAF's
3 DPFE sensors
EGR Valve
3 MAF's
If you can't tell me what code it being thrown then I can not tell you how to solve the problem and clear the code/turn off ses light.
Why do you keep throwing the same parts at it.
Codes..........Need the codes
What kind of tech are you????
If codes are setting off the light, then you need to resolve the issue to clear the code and the light will go off.
As I said, the codes thrown are for lean condition, bank 1, I'm not sure the actual codes at this time, and what do you mean by "what kind of tech are you".....I'm a certified auto tech (everything but automatic transmissions) and I've also had Ford specific training.
As for throwing the same parts at it, they were under warranty from the parts dealer, most of which tested bad...for example I did get a faulty MAF the first time around, and the plenum spacer did in fact warp AGAIN.
Received 3,110 Likes
on
Did you replace those parts to try and solve the problem or are they just parts that have been changed?
As for the parts themselves, If you need to replace every part two or three times, because of faulty parts......you need to find a need parts dealer.
I noticed in your first post, that you stated that no matter how many times you reset the light, it keeps coming back. That is why I asked what kind of tech you are.
You may be right, but if I were him, I think I'd try an o2 sensor from a different supplier first. I'm not sure where he gets his parts, but If got that many bad parts, you can bet I'd be moving on. It also makes it hard to solve a problem if you're not sure you can trust the parts you're putting on.
If you have not already done so, I would suggest using "Search" to search the 4.2 forum for "lean" and the specific code(s) when you get them.
There is a lot of history here and the answer might be sitting in an old thread just waiting for you to find it.
(example: I remember the little rubber elbow going to the PCV valve was bad to fail and cause lean codes)
Best of luck!
Best of luck!
If you scans read "lean on both banks", i bet you have a vacuum leak. Had the same problem in a ranger of ours. Both banks said lean, talked to a guy at advaned, when he scanned the codes, he suggested that, and after 2 min of checking the vacuum lines, a line had come loose from i dont know what it is, but it cleared the codes. You might try that.
There could be a few reasons for the lean condition, but you already know that. Codes will go along way to helping you solve your problem.
Hope for the best! You might get lucky.
Oh and a FWIW... I have been hanging out here for 10 years. This thread is an example (to me at least) of some of what is the best about FTE.
A few feathers get ruffled - maybe just a little bit - and good guys make things right and then go about trying to help get a problem fixed.
Good job fellas!
Good job fellas!
on
