Turbocharged 4.9L 300
The truck is a 1991 Ford F150 Custom 4.9L turbo putting out 244 rwhp and 400 rwtq at 10.8 PSI on 91 pump gas. I know many people have trucks like this and would like more power but there is no support for it. In this write up I will tell how I did it and what I used to do it.
First off the motor its self is stock except for the RV cam, the stock one might have given me more power to be honest. I built a remote mount turbo set up using a turbo from a 94 6.5L diesel chevy, 42lbs fuel injectors, one piece charge pipe from the turbo to the blow off valve which is a Type R, then to a custom Y pipe going into the throttle body. I used a oil filter adapter plate from Pro Sport gauges to run the -6 stainless braided line to the turbo. Then used 1/2 inch high temp rubber hose from the turbo to the Turbo Werks oil pump then -6 stainless braided line from the pump to the oil fill cap of the engine. All Vaccum lines have check valves so the HVAC and fuel system doesn't get pressurized when the turbo builds boost. The ignition system has Taylor wires, cap and rotor, I'm also running a MSD blaster coil and MSD 6-BTM Boost Timing Master. I'm still running the stock speed density tunned using a SCT chip. It has taken a local speed shop and I about a month of tuning time on the dyno. As far as I know we have been the only ones to tune one of these truck. I will have all the info at the end. To keep an eye on the vitals of the engine I use a EGT gauge, fuel pressure gauge, boost/vac gauge from Pro Sport, and a Wide band O2/volt meter/turbo timer from innovate motorsports with the LC1 Wide band sensor.
All pics of the build can be seen in my profile or at http://www.cardomain.com/ride/2147225
The speed shop that helped with the tuning is APS in Oklahoma City OK, 405-424-7223 ask for Bo
Ill be happy to answer any questions about the build
I would think that return would cause the oil in the turbo to back up and not drain properly. Since gravity is working against it.
You could always weld a bung into the oil pan then if you ever ran into a problem you could just plug it.
Cant wait for a video.
EDIT: I just read that you have an oil pump. NVM then..
the turbo starts the build boost at 2000 rpm, the cat is not gutted and the hole has a 1/4 inch pipe welded into it so the frame wouldnt loose any strength. I really dont think you would want to put a smaller turbo on it. a smaller turbo might not be as efficent and would all ways be in boost and could cause damage to your engine and the turbo would run out of steam at a very low rpm. i make max power at 3252 RPM with that turbo and its already putting 10.8PSI to the throttle body.
Dont let not having a tuner in MA stop you. If this is a build you want todo Bo at APS here could take what you have done and put a tune on a motes or SCT chip and get you running. it really didnt take much at all once we figured if we could tune using the factory computer but its at its limits for this build if i want more i will have to use a differnet computer.
i think that the 6.5L turbo might be a bad choice of turbos actually.. they are super tiny little turbos and IIRC they only ran off of one side of that engine???? so really you could put on something much better like an HX35 off of a cummins and have a more reliable turbo. It might spool a little bit later and shift your power range up a little, but thats better in a gasser IMO anyways. I never have liked those little bity turbos. wonder what one could do with like an HX40 or an S366.. move some major air in there.
I'm pretty sure that you could get something better on there is all i'm saying. those 6.5 turbos from what i have seen aren't the most reliable little things out there. for the price, why not use it right? I just think you could get an HX35 to spool good and probably flows a lot more CFM.. Maybe even the turbo off a later model common rail cummins. they flow a lot of air(good for 500hp in a cummins) and have a really tight turbine housing(9cm)... They are also reliable as hell.
I'm just trying to throw out ideas man.. not knocking your setup. it works and if thats what your stuck on then awesome. Ideas never hurt anyone though.
