Fuel Line Quick Disconnect '96 F150
I have a cheap fuel line disconnect tool from O'Reilly Auto. I cannot get it to work to disconnect my rear fuel pump. Is it just because the tool doesn't quite hit the springs right, or what am I doing wrong? I've watched several videos where people seem to get them off fairly easily, & I push on the connection in the same way, but it just stays in place. I'd love to get this changed so I can drive this truck again.
Thanks in advance for any advice you might have.
Paul
96 F150 RCLB 4x4 XLT 4.9 5spd M5OD
94 Ranger 2wd XLT 4.0 A4LD RCSB
Paul
Clean grit out of the coupler with something. Carb cleaner, WD40, etc & blow out with compressed air if possible. Spray again, then try. Also sometimes the plastic ones work better over the scissor style.
They baffle me as to why they work flawlessly sometimes & others, nearly impossible.
Throw that aluminum, scissors-shaped thing in the frickin' garbage.
Go to Autozone, or wherever, and get the colored set, blue, gold, and two others. It's not cheap, but good tools never are.
I fought with that same fitting using the cheap scissors thing for an hour. Bought the better tools and had it apart in less than a minute.
khakushia
03-08-2012 04:21 PM
FizzleBent
09-30-2008 01:42 PM
