Hidden Tailgate Latches Woes and Troubles
Anybody had any probs with the hidden tailgate latches. Installed them in my 55 Ford. Install went fine. Drill 3 holes in the tailgate. Dremmel a little out. Latches fit fine. Look good.
Matching it up to the bed. Not so good. It looks like it goes right were the the stack pocket and bed join. Tailgate is pretty flush seated to the bed. I dont wanna drill a 1/2 " hole right there so the spring loaded stud can seat into the bed. Bed is brand new. Tailgate is brand new. Dont think anything is off kilter Anybody got any suggestions? I was thinking I could grind the spring loaded stud flat(It has a little pointy nipple to it). Weld a little metal piece to the bed as to stop the stud from going back. Paint it and call it good. Attach a little rubber end to the stud too as to not scratch my bed.
Thanks
Thanks
Thanks
Thanks
you gotta drill the hole in the bed..
if I had to do it over, I would use the latch style vs the pin style. the bed & tailgate wiggles/flexes and will mar the paint.
also, the grommet they give you is worthless.. won't stay in, and doesn't protect well anyhow..
i also ground the pointy tip down flush..
sam
Ditto
Have to drill a receiver hole on bedside. I fabbed my own bedside, hidden pin latch and welded a washer on the inside of the bed to re-inforce the box. I need to shave more of the pin off so it seats better. I am using plastic plug inserts (for hydralic applications) to seat the pin in box. They haven't fallen out yet; over 5 years of truck sitting in garage. LOL.
I use the stainless cables for supports..
here is a pic of the latch pin hole..
Sam
that standoff for the latch handle looks interesting.. wonder why they did that..
and thats another thing.. which way the mount the handle..
pull the tailgate IN towards the front of the truck
or
pull the bedside in towards the tailgate
Sam
I think those are the latches shown in the MF catalog page above..
or
Sam
or
Sam
Here are some pictures of mine. They are adjustable. I put a small rubber bumper on the edge of the bed and then adjusted the latch to pull the tailgate tight against it. No rattles! I have had to adjust it once in 3 years and nearly 8000 miles. They have a button you have to press to open them and of course a cotter key through the hole is a positive lock.
I've had one.. tailgate related too.. just home from the painter I managed to push her back into the garage door (I SWEAR the parking brake was on AND it was in gear.. not...)..
rubbed a pencil eraser sized hole all the way down to the metal on both the top & bottom rails of the tailgate.....
had to repaint the tailgate.. do NOT want to do that again..
where did you get the adjustable latches.. pretty cool..
sam
or
Sam
or
Sam
I was wondering the same thing about the standoffs. I bet its so they didn't have to drill holes through the bedside or tailgate. Thread a little steel plate, weld it to the bed/tailgate, and then mold it in. Pretty slick.
