Simple, Stupid axle question
So even though my 96 axle code on the fordification site has the NL the 95 is the same even though it doesn't say NL beside the ratios?
I will take some pics of the factory unit and post it... Why? Because I actually have one from that specific year, sitting in the bed of my truck completely open and viewable! This is one of the few times I actually have something like this readily available! LOL!
Here ya go..
I am really curious too! I wondered about this, as I have the entire differential assembly I just took out of a 97 F-250 HD with 4.10 gears. My gear tag reads as follows:
S 132 N
4L10 10 2 7030
Here ya go..
S 132 N
4L10 10 2 7030
That looks like a Limited Slip to me. The hump ^^on the right hand side near the bearing is the slot for the clutches.
Here's an open carrier
Jim, Right on! Thank ya much!
I have never had issues with swapping out gears, or replaing them, and making sure not to misplace the parts as I go and putting them back in order.. The identificaiton process however.. Eh! LOL! Havent really had a need to until recently with the whole 4-wheel drive add on, now a little more attention in needed! Thanks a million!
Originally Posted by redman84;9065001My axle code is S129N which translates to 4.10s on a sterling 10.25 with [B
NL.[/B]
I believe the original post was about the "L" or the "NL" in one of the columns on the fortification.com chart.
Everyone agrees that the "L" within the numerical ratio (ex 3 L 55) means a locker. But what does the "L" and the "NL" in the website's column mean?
I happen to have two 10.25" rear axles with 3.55 gears, one from a '96 F250 and the other from a '96 F350. At least that is what both tags say. The F250 axle tag is marked "3 L55" and the F350 axle tag is marked "3 55". No doubt about it, the one tag does not have an "L" between the 3 and the 55. Yet both axle codes are listed on the fortification.com site as being "L" in the "NL" or "L" column.
So, back to my questions....just what does the "L" and the "NL" in this column signify?
Many thanks!!
Leo
Received 3,110 Likes
on
Thanks tjc transport!!!
So where do we vote for the Snow and Baby Bunnies for President? Gotta be better than the choices we have!!
So, back to my question....just what does the "L" and the "NL" in this column signify? It clearly has no bearing on wether is is a locker differential or not.
Edited to add: Now that I am paying attention, the NL and L seem to correspond to the tag on my two axles having/not having an L in the ratio number. The NL means No Locker, the L means yes, it has Locker.
Sorry for making this issue way more complicated then necessary!
on
on
Sterling 4.10 limited slip.10.2 ring gear. 1997.someone else can tell ya the month with the 030 at the end iirc (but it's of no importance.)
if the axle in the truck is factory,the axle code on the door will tell you if it has LS or not too.
quick way to remember; if the axle code starts with a number it's an open diff.if it starts with a letter it's got LS (or did when it came from ford.)
someone replaced the carrier in your axle back along,or swapped tags cus it clearly has an open in it now.
oh i see the site again.well that's ok and all.but you guys want this one too:
http://www.drivetrain.com/parts_cata...s_it_posi.html
this axle code is found on the drivers side door jam sticker.this is only good if your sure the rear is stock though.
