Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 06-28-2010, 10:57 PM
SoloAK SoloAK is offline
Garage is empty, add now
SoloAK is starting off with a positive reputation.
Rear end gear ratio specs for 83 F250
Can anyone possibly help me with the rear end gear ratio for my F250? I've looked all over the place and can't track it down. The code is B6, but can't find anywhere that will give me the ratio. The rear end went out and I need to get another one, but can't until I find the gear ratio for it. Thank for any help.
  #2 (permalink)
Old 06-28-2010, 11:12 PM
FordNFishinLover's Avatar
FordNFishinLover FordNFishinLover is offline
FordNFishinLover is starting off with a positive reputation.
put down the code on the tag of the rear axle so we can identify it for you.
__________________
1981 Ford f-100 302/C6/9'' 3.50 limted slip/31x12.5
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
  #3 (permalink)
Old 06-29-2010, 02:45 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.Festus Hagen has a very good reputation on FTE.
The info I have says B6 is a 3.73LS for a F150 ...
Is the B6 from your door sticker??
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
WANTED: Factory Turbo Wastegate Housing.
1994 F350 XLT CrewCab Dually IDIT ZF5 4.10's
1986 F250 SuperCab Dually 4WD 7.3IDI T19 BW1345 D50/60TTB Sterling 10.25 3.55's
1991 F250 StandardCab 2WD NO-IDI NO-ZF5 Sterling 10.25 NO-4.10's - Gone to the Toyota factory!
  #4 (permalink)
Old 06-29-2010, 02:54 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen is gaining momentum as a positive member of FTE.Ken Blythen is gaining momentum as a positive member of FTE.
The chart I have gives B6 as a 3.55 limited slip for 83/84.
Is the tag still on the axle as FordNFishinLover mentioned?
The axle may not be the truck's original, so the door sticker might lead you in the wrong direction.
__________________
1983 F250 XLT 2WD, 351W, T19, 3.54 Dana 60
1983 F150 302, T18, 3.55 8.8, Supercab - parts truck
1941 Ford 1 Tonner - deceased
1942 GMC CCW-353 6x4
  #5 (permalink)
Old 06-29-2010, 03:24 AM
Methanoholic
I'd be more likely to believe that then what I have ...
-Enjoy
fh : )_~
__________________
  #6 (permalink)
Old 06-29-2010, 05:30 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B6 = 1983/84 F250 / Ford WFL 8.8" Rear Axle / 3.55-1 / Limited Slip / 4,500 lb. Rear Axle Capacity.
1983/89: The so-called Light Duty F250's used the Ford 8.8 / Without Limited Slip, the F250's Ford 8.8 is known as the WDR.
I just know that someone's gonna chime in and say there ain't no such thing. Since this subject has been brought up several times in the recent past...
Take a gander in the 1980/89 Ford Light Truck Parts Catalog = Text, Section 40, Page 10 of the Rear Axle Applications Charts, and you will see that there was.
If this truck was a so-called Heavy Duty F250, it could have either a Dana 60 or Dana 61.1.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #7 (permalink)
Old 06-29-2010, 06:38 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
ND brings up a very good point. I remember seeing the F250 8.8" axle many years ago. Most semi floaters I saw were the 10.5 though.
Does this truck have a large center that protrudes from the rear wheels, say 2-4", or just enough for the wheels center hole to fit over?
ND, does the F250 8.8 use the same rear axle bearing as the F150 8.8?
I bring this point up due to the fact that this member mentioned the rear axle was run with a low lube level, and if it uses the same bearing, it *could* be the cause of the whining noise they were asking about in another thread.
Of course, even if the axle is a full floating design, the whining could be from the rear wheel bearings.
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #8 (permalink)
Old 06-29-2010, 09:20 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
B6= 83/84 3.55 4.50M Ford Limited Slip
__________________
Dave F
1989 F250 XLT Diesel
  #9 (permalink)
Old 06-29-2010, 09:31 AM
Quote:
Just to translate for the OP, 4.50M = 4,500 LBS.
__________________
  #10 (permalink)
Old 06-29-2010, 10:11 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
While the 10.25 (the 10.50 came in 97 and newer units) is the most common for the 85-96 250's, I do have in my possession an 8.8 axle under a 250 with 8 bolt wheels, so if anyone wants to doubt, I can snap pics...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #11 (permalink)
Old 06-29-2010, 10:14 AM
Quote:
My bad, I meant 10.25, but I hadn't got my 1st cuppa coffee yet....
Thanks for the clarification and confirmation.
Prior to ND mentioning that this critter *actually* existed, I thought I was misremembering or hallucinating......
__________________
  #12 (permalink)
Old 06-29-2010, 03:43 PM
Opossum Opossum is offline
1989 Ford F-350
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
Ohhh Please please please snap some pics, I gotta see that, and have proof, my Ford freak friends wouldn't believe me if I told them it existed.
  #13 (permalink)
Old 06-29-2010, 10:16 PM
fellro86's Avatar
1978 Ford F-150
Ok, I guess I don't have a 8.8, as it has a rear drain plug. It appears to be a Dana 44, without the floating hubs.
axle pic moved to my next response.
Click the image to open in full size.
__________________
  #14 (permalink)
Old 06-29-2010, 10:26 PM
Darn it! the only pic I can see is the one of the 3 lug wheel........
__________________
  #15 (permalink)
Old 06-29-2010, 10:34 PM
fellro86's Avatar
1978 Ford F-150
I will separate it out for you...
Looks like I have a little more poison ivy to kill... lower right corner. I respond badly to it...
__________________
Tags
1980, 38, 83, end, f100, f250, ford, gear, gears, harley, olds, ratio, rear, rearend, specs, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
