Go disc Brakes on rear or stick to drums?
Here's one of the most comprehensive kits I've found:
8 lug disc brake kits - NC4x4 Forum
A member from one of my local forums builds them.
there are 2 vendors on pirate 4x4 that sell them and should be able to help. One sells the brackets and you add chevy calipers, and the other comes complete as a kit but it seems more expensive to me:
Blackbirds Custom trucks - Professionals in Rear Disc Brake kits
RuffStuffSpecialties.com - Off-Road Fabrication Parts
additionally, i just found these options on SSBC's site:
Shop By Category - Front Brakes - Disc Brake Conversions & Upgrades
If you are not hauling loads or towing a trailer and your F100 is just a cruiser I would stick with the drums front & back. Do a complete rebuild back to OEM spec's and you should be good to go. I have done a complete rebuilt of my drum/drum setup on my 1971 F250 and it works fine. If you are doing something with your F100 that you need disc I would look into why or what you are doing with the rig. Just my 2cents, good luck with your rebuild.
68F100351W
10-26-2020 01:15 AM
Callantom
23
05-08-2010 01:39 PM
min150mph
17
10-05-2003 05:52 PM
