HEI distributor ?
HEI distributor ?
Hey guys n gals, I kinda started this in another post (engine progress and pics) but I would like to know how to go about hooking up the HEI dist to the motor once I'm done putting it together. I have installed a new wiring harness a couple months ago and have to old points type dist in the truck now, so all I have is the coil wire running to the coil. Is/what else would I need to get it going or should I just go ahead and put a points style dist in the new motor.
I have an MSD drop and drive distributor on my FE and it is fantastic.
All you need to do is hook up the connections per the instructions, to a 12 volt coil (and I REALLY recommend you get a FLAMETHROWER solid pack 12V coil)
AND
with the HEI distributors, you delete your ballast resistor. As Jaye mentioned, they like a full bite of power. It will work fine on your current electrical system as long as you are running an alternator and not running a 12 volt generator.
The generator will not produce a high enough charge to feed anything on the truck at idle rpm and when th ebattery kicks in to suply power, it's unassisted voltage is not high enough to feed the HEI system properly - it'll work, but it may idle sloppy.
AND
So I just need to run one 12 volt wire to the distributor correct? Can I use the coil wire once I remove the ballast resistor and where would I hook it up at. This is the dist I got from summit.
Summit Racing SUM-850021 - Summit Racing® Blueprinted HEI Distributors - Overview - SummitRacing.com
So far all I can see is 2 wires that come out from under the cap and they go up to the top of the cap by the coil and plug in. I dont see anywhere I can hook up the 12 volt wire. Am I missing something here?
The top of the Distributor is the coil. In the picture, if you follow the black portion to the right where the wires from under the cap plug in, there should be two additional tabs in front of them. There is a standard HEI male plug that fits there to clip to the tabs and the wires are generally a single 10 ga and a 14 ga. The 10ga is for the power from the ignition or switched power that is 12V without the ballast resistor. Does that help? Steve
Awsome that sounds good, it would be nice if all I have to do is hook up 1 wire. Ive been told HEI is better than the old style so I figured I'd give it a shot.
one wire is right , to the dizzy the other is the tach . coil is in the top of the cap , and i hate to say this , but the hei is one thing gm got right . it's the best factory electronic ignition system made in it's time . that's why davis and others have adapted it for use in every thing under the sun .
