Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
- How to Replace Fuel Filter
Step by step instructions for do-it-yourself repairs
fuel filter canister removal
Time to tune up the '66 F350 I purchased last winter. The fuel filter canister won't budge - probably last changed when Reagan was in the White House.
Any tricks to removing a stuck fuel filter canister?
Is there a tool that fits over the bottom?
Thanks, Tony
1955 F350 dually dump
1966 F350 dually dump
Thanks, Tony
A pare of pliers with a towels to keep from crushing the cansiter works sometimes; just keep the pliers up on the top portion of the cansiter. If you attempt to turn in the middle you can collaspe the bowel. Use some PB Blaster or other rust buster along the lip to hopefully lossen the tarnish fuel and debris as well.
If you have a strape type wrench; craftsmans & harbor freight sell this type of tool as well as plumber type tools stores; you can use it to turn the cansiter as well.
I also have use a pare of pliers that are specfic for oil changing; they have teeth along the lip to grip; but again don't put pressure on the cansiter in the middle due to it will collapse.
Hope this helps; I'm sure there's a proper tool made; but I'm lacking in that department.
If you can I would visit Napa for advise as well;' and try & get a psare one from a salvage truck for back-up.
Mitch
Mitch
The following users liked this post:
On the bottom...original ones have a huge hex head stamped in it...a carefully placed and covered crescent wrench should do it.. Make sure the cannister and the area immediately above it is clean and free of grease...dry, wash hands, dry...then get under the truck and get up close and personal...and remember lefty loosy(counter clockwise), righty tighty(clockwise...as you are under the can looking upward at it...it is hard to break loose...but not impossible...a good grip and it will move...the gasket is about 1/8" thick and has a good seal usually .
I have an old pump from a FTE member here who replaced his pump...can looks good...but that filter looked dreadful...NEVER seen ANY filter that nasty...
Im assuming your truck has the 352...6 cylinders are can side up.
- cs65
- cs65
C4AZ9365B .. Cartridge Fuel Filter w/gasket (Motorcraft FG1A) / Available from Ford.
Fits myriad 1963/77 Passenger Cars/Trucks/Bronco's & Econolines.
C3AZ9355A .. Cartridge Fuel Filter Cannister-threads onto fuel pump / Fits same as above / Obsolete
Available from some autoparts stores. Ford Dealers, obsolete parts vendors have over 500!
DON SANDERSON FORD in Glendale AZ has 168 = 623-842-8762.
I replaced my pump and put Vaseline on the seal and a year later is was still so tight I had to get and old belt and some pliers to get it off. I put the strap around the bottom of the canister.
I think the pump was around $40 at Autozone. They are wear items so I replaced the pump as insurance I would not fill the oil pan with gasoline.
