I baught the engine at a junkyard so I know nothing about it
The numbers behind the starter start with E4AE , does that indicate a 1984 engine? If it is a 1984 why would it have what looks like a crank shaft position indicator with a white and a blue wire cut off at about 1 foot? I do not know what should connected
Who knows. What really matters is what you're putting this in and the electronic requirements of that vehicle, if the system in it doesn't use a crank sensor then delete it and forget you ever saw it.
