Convert FT To FE?
No.
Engine mounts are different.
Bell is different.
Flywheel is different.
Crank snout and balancer etc different.
Exhaust manifolds probably different.
You might be able to adapt it. But it would take a side-by-side comparison and swapage, and some reworking.
I'd fix the 389 if it's fixable. jmo.
And then it's a 352--how tired is that motor?
Bell is different.
Yup, pilot bushing is different inside diameter for the bigger trannies, I've heard. Clutch, well, that's another problem. Can't use the FT flywheel on the FE because of external/internal balancing...
This might be a dumb question but here it goes.... If a person was to mix parts of said engine with internal and external balance would it just shake the fillings out of your teeth or only be drivable up to a certain rpm? I am guessing maybe it would shake it self apart? Taking into consideration the same machine parts. I always wondered about this more out of curiosity than anything.
I pulled a 330 M/D engine and took the flywheel, clutch, pilot bearing, pressure plate, and release bearing and swapped it directly over to my 352 FE with no problems, runs real smooth. The 330 M/D doesn't have the forged crank like the 330 H/D so the flywheel doesn't have counterweights.
FT to FE
It depends on the FT that you have the diameter of the distributor shaft. 330 MD's have the same size as a FE. Also the crank, flywheel , bell , pilot bushing all interchange. Some of the larger FT's use the large distributor shaft, but there are a few exceptions , you must check size to be sure. For certain any big snout FT has a weighted flywheel and should not be used on a FE. FT bells will bolt to any FE, pilot bushings/bearings are available for either crank. The front mount from a 330MD will let you mount a FE into a chassis where a FT was. Early FE's from pickups and 1 tons are also a source for front mounts. You can use a FE flywheel for the conversion , but it will possibly have to be drilled for the larger clutch assembly. If you weld the crossover up on a set of FT manifolds they can be used on a FE. Typically a FE will work OK in a heavier truck but long term durability is an issue, they don't last as long if loaded heavy. They have a tendency to valve burning and recession. FT's use a heavier piston with 4rings , but FE's use a lighter piston with 3rings. This leads to less durability. If your goal is a show truck or a
lighty loaded or occasional use truck , then a FT to FE will be an OK choice
I've done this swap many times, mostly with good success, if you have any questions let me know.
Have A Great Day-----------------Hotwrench
Except that using a 330MD timing cover and other parts will help you put an FE in where an FT used to be. For instance, use a 330MD timing cover with integral motor mount, and you're able to bolt a 390FE into where an FT fits, like an F600.
Pilot Bearing
As discused 330 MD's use a 360 crank , its the same crank that is in thousands of pickup trucks . Therfore a pilot bearing for a 330MD will fit into a 360/390 FE as they are the same diameter. Hollander interchange on a 330MD/FT crank is as follows #209 fits A B & C interchange by including timing chain sprocket B is heavy duty.
A. C4AZ6303 cast# EDD, EDT, COAE-B, C3AE-A, C4AE-A
Edsel 58/59 Ranger / pacer 8-361
Edsel 60 8-352
Edsel 59 8-332
Ford Pass 8-352 8-332 58/63 includes Merc 352 61/62, T bird 352 58/62
B. Ford Pass 60 8-352 Special
C. C4AZ6303L cast# C4AE-E or 2T
Ford Pass 8-352 64/66
Ford Tr. 8-330 MD 64/up
Ford Tr 8-352 65/67
Interchange # 401 C8TZ6303A cast# 2T
Ford Tk 68/72 8-330 8-360
Ford Tk 73 8-330
Ford Tk 8-360 before ser # Q80,001
This is just a partial listing I can provide more info if needed if you need part #s for pilot bearing let me know.
Have A Good Day----------Hotwrench
Edsel 60 8-352
Edsel 59 8-332
Ford Tr 8-352 65/67
Ford Tk 73 8-330
