Oil PSI and Compression check results on my flathead
Well I went to auto parts store and bought a mechanical oil pressure gauge because the one in the truck was reading low and I borrowed a compression checker gauge from a local shop. The oil pressure was consistent from cold start to warm at about 47-50 PSI. Some one had rigged some kind of funky oil system to the engine before, so I took it off so there wasn't an oil filter. Used pennsoil straight 30w oil. I do have the correct oil filter to put on it I just wanted to do the test first before I spent money on a new filter. I know that not running a filter gives a little more PSI anyways. P.S. after I took the old oil system off and put the mechanical guage on I still had the guage from inside the cab hooked up and it read 32 psi which was a little better than before when it had the funky oiling system on it.
The compression test showed 105,107,100,99,99,94,110,101. So highest being 110 and the lowest 94. I don't think the throttle was all the way down when I did the cylinder with 94 psi didn't realize it till I was already on my way back to the shop. The shop I borrowed the compression checker from said that was good. All I can say is its getting REALLY hard to even think about putting the 302 I have in this thing.
Sweet, that makes me feel a lot better guys. If I do go the flathead route I have a 9 inch I bought to bolt under the truck either way 302 or flathead. The gearing is 3.70. I wasn't going to touch it if I went the 302 route, but if I go flathead I think ill go with 325 gearing with stock 3 on tree. But....later on when the flatty would have to be rebuilt I would want to have a 3/4 cam put in it cause i have herd flatheads with them and they sound amazing, but the 3.25 gears I know would be to high for that. I guess I could just keep my 3.70 gears hmmmm. The farthest I would want to drive it would be to pigeon forge for supernationals about an hour and 45 min from me...... and of course around town.
The reason I'm just not JUMPING on the flathead is that about 4 years ago My wife bought me a chassis engineering MII crossmember with SBF motor mounts already welded in place. I don't have the complete kit just the cross member but that thing was about 700 bucks! I know I couldn't get my money back out of it if i tried to sell it.
I couldn't put it in because of exhaust issues. I was able to sell the kit and make a few dollars on it.
Never say Never.
brain75
31
02-05-2016 06:01 PM
jublydan
09-15-2015 02:26 AM
