1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Needs some help with some engine codes
Old 06-19-2010, 09:52 AM
softie's Avatar
softie
softie is offline
My ABS light has been going off every so often in my car. Then a few days ago my CEL went off. So instead of being raped by the dealer I decided to finally use my reward points from my credit card and got me a scan tool with abs on it. When I hooked it up I got a few codes but it also gave me several fixes for all the codes or none at all so I was just looking for advice on where to start with the codes.
C1155 - Left front speed sensor input circuit malfunction
C1145 - Right front speed sensor input circuit malfunction
C1158 - Left Front sensor coherency Malfunction
B1676- Battery pack voltage out of range
C1226 - Brake warning lamp ground short
P0401- Exhaust Gas Recirculation flow insufficent detected
Old 06-29-2010, 05:18 AM
softie's Avatar
softie
softie is offline
Alright well I guess i'll just bring it to the dealer then.
Old 06-29-2010, 11:19 AM
alloro's Avatar
alloro
alloro is online now
Received 4,196 Likes on 2,432 Posts
Hmm, must've missed this post 10 days ago. In the future if you don't get a response within a couple of days, bump it up to get some attention.
When the ABS codes get displayed the scanner should specify if they're current codes or in history. For the moment, ignore the one that only say history and see which one(s) say current. Of course you can only get a current code if the ABS light is on.
As for the P0401 code, remove the EGR valve and check the passageways behind it to see if they're clogged with carbon build-up.
Old 06-30-2010, 03:21 PM
jdecker's Avatar
jdecker
jdecker is offline
What year is your truck?
Old 07-09-2010, 05:43 AM
softie's Avatar
softie
softie is offline
Thanks.... Well I tried to take it to the dealer but ended up getting mad and leaving cause of the guys attitude. So The only codes left are 2 for the front left speed sensor. The issue im having with this one is the meaning of them both and also the light isnt always on. sometimes it will pop when i turn it on or it will come on eventually or sometimes not at all. So if the issue was with the sensor directly would it always come on from start. Once it comes on it doesnt go off unless i clear the code. As for the egr valve. I checked it and all the vac's and the hose and they are all clear. So I dont really know what to do next. Also the truck is a 2001
Old 07-09-2010, 06:31 AM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
The code P0401 is also sometimes caused by the DPFE going bad. The aftermarket ones have had questionable reliability, so I would stay away from them.
Old 07-10-2010, 02:14 AM
softie's Avatar
softie
softie is offline
So should I just go to the deal for that part?
Old 07-10-2010, 07:02 AM
c_hohensee's Avatar
c_hohensee
If you can wait I would check with one of our sponsers such as partsguyed. You can usually save a fair amount getting it on line.
Old 07-10-2010, 02:51 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
help with error codes
you can also get info from Google and this site:
Most Complete List For Ford Check Engine Light Codes
Old 07-12-2010, 01:59 PM
softie's Avatar
softie
softie is offline
Thanks.... ill look around the site for it
already tried google and that site and all it did was tell me what I already knew. But thanks for your input.
Old 07-12-2010, 04:51 PM
FordVARunner's Avatar
FordVARunner
FordVARunner is offline
If money is really tight you can go to the junk yard and get the DPFE sensors from another expedition, focus (2000), or taurus (2000). Just stock up on those bad boys if you know what I mean.
Old 07-12-2010, 06:38 PM
softie's Avatar
softie
softie is offline
Well since im selling my WRX on monday. Money really isnt an issue because I have to get to work no matter what and sometimes you have to pay to get it done right
Old 07-14-2010, 05:34 PM
softie's Avatar
softie
softie is offline
Heres a Question...... Im having a misfire in Clyinder #5. How do I know which one is which? Ive been searching the forums for quite some time for this but I dont even think im searching for it the right way.
Old 07-14-2010, 09:20 PM
alloro's Avatar
alloro
I'm having a misfire in cylinder #5. How do I know which one is which?
Looking down from above:
firewall
-4---8-
-3---7-
-2---6-
-1---5-
radiator
Old 07-14-2010, 10:12 PM
softie's Avatar
softie
softie is offline
youre amazing!
Quick Reply: Needs some help with some engine codes
