hpop upgrade dilema
#106
#107
There is a company that makes a kit for the 7.3 SD's and I was looking into them, well they also offer a twin turbo kit, which is only for the 7.3 SD. Well reading into it, the small turbo is a S300, and the big turbo, well I forget. But I have been poundering a idea (Even doing a little scetching) of a setup for a S300 and a 76 Sledge. But I thought about seeing if I can get a H2E in 76mm and go that route (Cause from my understanding you should have the small turbo off the up pipes then the big turbo off to the side) and with a H2E is the same style they use for compounds on Cummins, so I know it would be way easier using it. Anyways thats the plan, that may never happen. I also thought about compounds with a supercharger. Then I could probably fuel it pretty good and it would still have superb street manners.
#108
This is an interesting idea. Ive seen it done a few times in the mags and it sounds legit. I like the idea of no lag! Anybody have anymore insight on the supercharger/turbo setup on a 7.3? I assume this would be similar to a twin turbo, maybe a little better, less lag, but a little less plumbing at least.
#109
Empire Diesel Performance has a supercharger to turbo setup for the 7.3 SD, which I assume could be adapted to out 7.3 and its a good picture
#110
Extreme 2.8 Comp Turbo
look at that setup for a DMAX (Picture is a DMAX but its spouse to be for our trucks) I like the idea.
#111
I got the pump installed late thursday night and than put close to 1000 miles on the truck this weekend. I went unloaded over several passes. I averaged about 18 mpg's but I was deffiniatly pushing it so I'm extremely happy with that number.
I've noticed:
It runs better
it starts faster
more power on low end but a good power increase on the hi end
I was averaging 70-75 mph on this trip and when it came to pass I would push it and I'd have the speedo maxed without noticing... She scoots
It was an easy cheap mod and in my opinion a very important one
#112
I've noticed:
It runs better
it starts faster
I've noticed:
It runs better
it starts faster
I'm about 17 mpg highway with my stage 2's and 15*.
#113
#114
#115
spongecop
10-31-2016 12:51 PM
exbxtoy
11-15-2015 09:50 AM
PaysonPSD
29
04-10-2009 02:35 PM
