Too much ethanol = CEL
Old 11-08-2009, 03:19 PM
pushr0d's Avatar
pushr0d
pushr0d is offline
Question Too much ethanol = CEL
My wife called me (of course, these things always happen when I cannot respond) and told me the CEL came on in her '97 Expy (5.4L).
I directed her to Autozone. She called, saying the code was a 'Lean Condition, both banks'.
She puts the Autozonian on the phone. He says he's seen a bunch of cars lately with the same problem. His 'solution' is to put a 'heavy' dose of either Gum-out or Lucas engine treatment in the fuel tank.
It seems to me that getting some fresh (and hopefully 'better') fuel in the tank would be the more appropriate fix.
What's the scoop?
Old 11-08-2009, 04:47 PM
fellro86's Avatar
fellro86
fellro86 is offline
I have not seen the light come on for lean fuel with high ethanol content, just an emission code. Lean condition would indicate possible fuel filter problems to me first. Unless you have put E85, I don't see any issue from just ethanol. If it were that simple, I should see it on a regular basis with just my family's vehicles, but do not. We even put in higher amounts, and as I stated, it comes out with a code from the cat converter being out of spec. That is an 02 Buick on e85... I am running 35% in a 91 Cavalier right now with no issues. Yes, it dropped 2 mpg, but that is a far cry from the 30% some claim, which would be 9 mpg on that car.
Old 11-09-2009, 08:36 AM
pushr0d's Avatar
pushr0d
pushr0d is offline
Thanks for the response!
I just got off the phone with my favored mechanic, and he said the fuel issue is BS!
He suspects either a vacuum leak or possibly a fault in one of the O2 sensors.
I gotta take it over to him so he can diagnose the problem.
He concurred that high ETOH will not throw a 'lean' code.
Old 11-09-2009, 08:42 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
If it is not flex-fuel, the injector sizes, that is the maximum flow rating, may not be enough to avoid leaning out too much with more than ten percent ethanol. No amount of additive is going to correct that. "Both banks" tells us that it is the pre-cat sensors that are involved, so the cat is out of the picture here. Usually a plugged fuel filter will have obvious driveability issues, as in reduced power at full throttle.
A vacuum leak is always possible. If the pipe between the MAF and throttle body has any leakage, that will throw things off a bit, but I thought the job of the pre-cat O2 sensors was to detect minor mixture faults and tell the computer to adjust. Throwing new sensors at a problem may or may not find it, but is relatively cheap.
Jim
Old 11-09-2009, 08:49 AM
pushr0d's Avatar
pushr0d
pushr0d is offline
J&M,
Thanks!
Yah, the truck is starting and running 'normally', so whatever the issue, it must not be too serious.
And I don't need to worry about high revs. I don't think my sweetie has ever had the engine past 3500 rpm.
I'll post the findings...
Old 11-10-2009, 08:53 AM
pushr0d's Avatar
pushr0d
pushr0d is offline
The mechanic just called.
Apparently the problem is a common one. The PCV elbow on the back of the intake manifold had deteriorated and cracked.
He's pretty sure that is the problem, but he will call me when he checks the car afterward.
Here is an interesting thread on the subject from OBD-II Trouble Codes - DTC Codes Car Repair
- 97 Ford Expedition codes P0171 and P0174 not a PCV leak - OBD-Codes.com
Old 11-10-2009, 01:52 PM
pushr0d's Avatar
pushr0d
pushr0d is offline
Well, I was gonna 'edit', but don't see how...
Anyhow, the problem was indeed a cracked elbow. However, the elbow is no longer available by itself; Ford is now selling a PCV hose assembly for a bit over $30.
So, ethanol had little, if nothing to do with the problem.
Old 02-15-2010, 07:25 PM
ExtrmZ's Avatar
ExtrmZ
ExtrmZ is offline
well thats good to know, there are problems that could happen because of the ethanol, gummed up stuff.
good to know it wasnt you
Old 06-14-2010, 11:33 PM
volksinthevalley's Avatar
volksinthevalley
volksinthevalley is offline
of course it is no longer available
Daniel Linares
09-06-2016 09:43 PM
tseekins
2009 - 2014 F150
25
06-28-2016 02:04 PM
cjben
27
05-03-2016 10:41 PM
ajg617
06-11-2015 08:08 PM
Catherine M Fisher
19
04-04-2014 03:44 PM
Quick Reply: Too much ethanol = CEL
