Sliding rear window question
Old 06-05-2010, 03:33 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
On Josh's 79 he got me a LMC window gasket set. I am not please with the fitment of them. The windshield and the rear window leak. Now with the rear window leaking for the past year there is RUST coming thru the new paint because the cab corners must be getting water down in where I could not get paint.
ANYWAY. I am going to rip this POS gasket out and have to repaint the entire back of the cab when i fix the cab corner rust. My question is.... where do i get a good gasket and which one do i need. This is the rear window. The latch says PASSPORT. But that is it
Old 06-05-2010, 05:01 PM
Rockstone's Avatar
Rockstone
Rockstone is offline
You could have a Passport rear window, or an OEM window with a Passport latch, since the original latches were plastic and broke if you looked at them funny. From what I understand, the same rubber was used thru 1996, so you could probably still get it from Ford. Search rear window rubber in here, I seem to remember somebody had a fix for leaking corners.
Old 06-05-2010, 10:22 PM
dadsold76's Avatar
dadsold76
dadsold76 is offline
im glad you posted this i have the lmc seals on my list of parts to get
Old 06-07-2010, 02:16 PM
dynamic's Avatar
dynamic
dynamic is offline
I usually use the mid 90's sliders and gaskets. The new style oem latch is far superior than that cheap plastic one.
Old 06-07-2010, 02:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
But...will the OEM gasket work with this aftermarket sliding rear window?
It's aftermarket due to the fact the POS Ford latch (that broke when you looked at) cannot be replaced with another type.
Here's the whole tamale.
F4TZ15422B30B (replaced: E2TZ10422B30A & D3TZ10422B30A) .. Sliding Rear Window KIT / Obsolete
Fits: 1973/96 F100/350, F(Super Duty).
F4TZ15422B30B =
There are 34 of these remaining at Ford Dealers.
E2TZ10422B30A =
UNION FORD L/M in Union City TN has ONE = 800-844-4090.
No other Ford Dealer, no obsolete parts vendor has any. No one has any of D3TZ10422B30A.
Old 06-07-2010, 02:37 PM
dynamic's Avatar
dynamic
dynamic is offline
You could replace the POS latch with another new relacement POS latch
<TABLE border=0><TBODY><TR><TD noWrap>Location:</TD><TD>Sliding Window Latch Kit</TD></TR><TR><TD noWrap>Make:</TD><TD>Dodge/Ford 1998-80</TD></TR><TR><TD noWrap>OE #:</TD><TD>4773094AB; E0TZ-1040860-A</TD></TR><TR><TD noWrap>Brand:</TD><TD>Dorman - HELP! - Carded</TD></TR></TBODY></TABLE>
Dorman Products - 76989
<TABLE><TBODY><TR><TD align=left></TD><TD align=left></TD></TR><TR><TD colSpan=2></TD></TR></TBODY></TABLE>
Old 06-07-2010, 02:48 PM
Rockstone's Avatar
Rockstone
Yeah, the Passport window does work with the OEM rubber. I know because I failed to tie down a tiller in my Dad's truck once and replaced the broken and mangled OEM window with a Passport. LOL. Did not know the latch would not work on the OEM though.
Old 06-07-2010, 03:11 PM
NumberDummy
While the complete assembly interchanges 1973/96 (see post #5), the weatherstrip does not.
D3TZ1042084A .. Sliding Rear Window Weatherstrip / Obsolete
Fits: 1973/79 F100/350 / 1980/96 is different.
GREEN SALES CO. in Cincinnati OH has FIVE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
Old 06-07-2010, 04:12 PM
robertbenita's Avatar
robertbenita
robertbenita is offline
I had great luck with Dennis Carpenter on an OEM Slider Window.
https://www.ford-trucks.com/forums/9...-question.html
Old 06-08-2010, 04:02 AM
Diesel_Brad
We just ordered the dennis carpenter one
Old 06-08-2010, 04:21 AM
NumberDummy
How much?
Did you happen to call the Ford dealer I listed that had a sliding rear window kit...to see what he wanted for it?
Besides the one gen-u-ine FORD kit I listed, there are 34 others available from dealers.
Obsolete parts cannot be returned to FoMoCo, which means the dealers are STUCK with them.
When this occurs, the parts can usually be bought between MSRP and dealer net cost...or less.
Old 06-08-2010, 06:33 AM
dynamic's Avatar
dynamic
dynamic is offline
The slider in the 97 and 98 F250/F350 only would be the same also! yes?
Old 06-08-2010, 07:50 AM
robertbenita
Best of luck to you Diesel_Brad! Let us know how you make out.
Old 06-08-2010, 01:04 PM
NumberDummy
Correctamundo.
Old 06-08-2010, 03:11 PM
robertbenita
After reading the posts, I called Green Sales Co. and asked about the slider window rubber and he advised that they are using a reproduction that sells for $75. He added that he had the vertical weatherstrips for the two Slider portions of the window for $6 each in case you need those. Really nice guy on the phone too.
The question I had that he could not help with is the tiny gasket that goes around each of the four separate sections of the slider window that is in between the metal and the glass of each panel. He said he could not find anything. Does anyone have any suggestions on what might work or where I might go to get something that would work. The gasket seems to be shrinking from the heat and pulling out from between the glass and the metal on two of the four glass sections. Anyone have a suggestion?
Quick Reply: Sliding rear window question
