289 exhaust manifold
Old 02-04-2003, 04:25 PM
Jim Larson's Avatar
Jim Larson
Jim Larson is offline
Question 289 exhaust manifold
I had noticed a picture on one of the threads that showed a standard exhaust manifold on the driver's side of a 460 Lincoln a guy was putting in his '66. The manifold appeared to be somewhat wedge shaped from the front of the engine to the back, with the dump end of the exhaust being part of the larger part of the wedge. If I have made the mental picture clear enough, can any of you tell me if there is such a manifold that would fit a 289? As I have a 289 in my '63, I think I might have some clearance problems with a power steering box I am trying to adapt and this might be a cure. Otherwise I may have to go to a set of headers - money I really don't want to spend. Thanks, Jim
Old 02-04-2003, 05:52 PM
cobraguy's Avatar
cobraguy
cobraguy is offline
Try a manifold off any mustang or fairlane that had a 289,302. I have a 302 in my 61 with a volare clip and the stock manifolds from the 84 donor stang. Plenty of room. Good luck, Rich
Old 02-04-2003, 11:23 PM
alpo23's Avatar
alpo23
alpo23 is offline
take a look at the hi-po 289 cast iron manifolds. they are simular to what you are discribing. Check with any good mustang parts house.
Eric
Old 02-05-2003, 11:08 AM
Jim Larson's Avatar
Jim Larson
Rich,
Thanks for the help. What do the manifolds from the '84 look like?
Eric,
Thank you,too, for your input. What years carry these hi-pro exhausts? Thanks again to all.
Jim
str8sixman
03-20-2015 09:20 PM
greyhound
1961 - 1963 F100 Unibody
10-12-2014 10:28 AM
Jim-4903
Modular V10 (6.8l)
02-08-2014 07:36 AM
plowboy12
02-02-2014 02:14 PM
ucmeflyby
10-10-2003 05:46 PM
Quick Reply: 289 exhaust manifold
