4.0 top half
Old 02-04-2003, 09:23 AM
460429_freak's Avatar
460429_freak
460429_freak is offline
4.0 top half
okay boy's I'm putting no 2 motor in my explorer, when I pulled the motor I saw the intake gasket has been leaking antifreze, well by learning the hard way I know I need to replace the head gaskets also,(when we replaced the intake gasket on motor no 1 the heads gasket started to leak on cyc. no 4)so I will have the whole top of the motor off.
so is there any GOODIES I should put in this motor at this point?
it has only 108000 miles on it the first motor made it to 238000 and still runs just weak.
Old 02-04-2003, 02:16 PM
98blownranger's Avatar
98blownranger
98blownranger is offline
4.0 top half
if this is the OHV you can get rid of the spring between the rockers and replace it with a alunium tube to keep them in place
open up the port on the exhaust side
