Fan switch questions rad or block temp?
Folks, I'm moving along with my 351w in my 52. I want to run an electric fan. I have some dumb questions. in the past I've only used electric fans for backup and pusher style units. this will be my first main fan system. where is the better place to install the temp sensor switch in the block or the radiator?? If I go with the radiator I'll use a probe style but where does the block style go and how do choose the correct range? I have a 185deg thermostat. Is that correct for this engine setup?
bob
bob
i used this one from speedway motors
it uses the temp gauge as the sender and has **** on it to make adjustments to when the fan goes on and off. easy to set up and you can turn the fan on manually with the ****.
Electric Cooling Fan Controls
personally i hate those push in the fins style sending units.....unreliable and off. new cars use electric fans as primary coolers and how many do you see with those type of sending units......none. in the past on customers cars and on my flathead (dist in the way of the stock fan) i run the sending unit in the block/head. my flathead runs a hotronics relay and sending unit and hasn't missed a beat, comes on when it should and goes off when it should. remember to use a good relay as the fans pull some amps.
Hotronics
Hotronics
Thanks all for the input. With a 185 thermostat what should the temp sensor be set to start and end?
My ez wire fuse box has a 30 amp relay built in it so I had planned to use that.
Also, I found a 6 blade flex fan here and with my rad in place it lines up well, I may just have to go this route until I can recover from other expenses..
I have mine set at 195 on and 175 off. My gage stays slightly below half way at all times and my engine seems happy and that makes me happy.
on
I use this same controller for my fans..
I actually use this relay control to control a local relay with direct power from the battery..
this reduces the power load thru the fusebox..
the sender in the intake manifold has varying degrees of ground resistance, and this allows you to adjust the time for the fan to kick on..
I currently use a 180 degree stat with my 460, but may move up to the 195.
sam
