temp gauge not going up all the way
i have replaced the thermostat, and i get good heat and it never over heats. the water temp gauge on the dash only goes about 35% of the way. bad sensor? how do i replace it? also i have a cel that comes on everytime i drive and stays on for 2-3 minutes, how would i check that? i know how to check a code if its always on but this is intermittant... thanks.
94 f150 5.0
94 f150 5.0
Codes will be stored even with the light off.
If you don't have a code reader you can learn how to do a self test here:
Ford Fuel Injection How To Run a Self-Test
I put an aftermarket mechanical gauge on my 93 F150 with a 300 and when the stock temp gauge gets around O, my real gauge reads 205. In the winter it would hardly get to the N and that would be right at 195. I got it up around the A one day and that was at 220.
The gauge reads really low from the factory, but im not sure how accurate it is. The stock location only take the temp of the water jacket and not the coolant after it goes through the head, and when i put my Mechanical gauge in the stock location, it was so close to the exhaust that it would throw the reading way off. I imagine the stock gauge might have similar issues, but they seem much less noticeable and hard to detect. I moved my mechanical pickup to my heater hose coming of my t-stat housing. It always has the hottest water and give me a good idea of how hot the engine really is running.
