FE why such a gashog ?
I drove a 360 FE for years, the FE is a great engine, but why the heck are they such notorious gashogs ?
Seems I must have talked to a dozen Ford truck owners over the years with 360s and they all got 10-11 just like mine did. I tinkered with mine many times playing with the carb, timing, bought a fuel economy guage, still could barely do 12. The truck was not low geared, either.
By comparison my 81 has a 351M and is 4wd 3/4 ton and it can pull 15 with the air running.
With the 360, it was a combination of low compression, cam, and from 1972 and up, cam timing. That, and the 2bbl carb they put on them.
A small 600CFM Holley vacuum secondary, all other things being the same, gave me much better gas mileage on the highway, and that was with a '74 highboy with 4.10 gears and 31" tires. I think it went from 10 or so to 15 on the highway if I was nice to it.
And yes, I used a 4-to-2 bbl adapter
If you were to up the compression a bit to say, 9-9.5:1, a decent "rv" cam (degreed correctly), and a 600CFM holley vacuum secondary, the good old 360 would do better.
But by that time, why not go with a 390
I'm keepin an eye out for a cheap Escort, Tempo or whatever in case we a big price increase in fuel (I hope I'm wrong) I like going junkin, fishin and out for country drives but it's not practical when your trucks are gashogs and fuel cost is an arm and a leg.
[quote=Econoline 150;8913028]It is a funny avatar. I heard that the FE's combustion chambers contributed to poor fuel economy, it just seems they were a little extra thirsty. Co worker had a International pickup with a 304 and a factory 5 speed and it got purtee good fuel economy for a 1960s truck. The GMCs in the 60s had a fine V6, but they were gashogs too. Just seems to me some engines even with similar size do better. I know gearing and all that helps, but still.
The thing about the combustion chambers, if one were to use the Edelbrock heads at about 9.1 compression, a performer intake and a 600 cfm carb with duraspark II or other aftermarket ignition could I then expect say 14-16 mpg?
"A lot of little holes is better than a couple of big holes."
That's why the 4V's smaller holes work better.
I also agree with, "if you do the same things to a 360 and a 390, the 360 will never come close to preforming anywhere close to the 390."
'69 F100
390 (10:1ish)
C6 (Super Streetfighter) w/2500RPM stall
3.73 gears
Performer RPM top-end (port-matched)
Comp ***** Thumpr cam
Speed Demon 650cfm
Performance Distributor
I'll be able to report back fuel economy then...
I honestly don't know, but I'm sure the Edelbrock heads are an improvement in many areas over the stock heads.
On my 360s I never did the adapter thing. Was always able to find a 4V manifold when I wanted one. However I did the bigger 2V a couple of times, up to a 650 CFM and the mileage just got worse. That's because of how carbs work. A Holley tech rep at a race in Tulsa said it best,
However, by the time you pay someone to do all that work to a stock set of heads, the Edels were the same (or close in) price.
If it were me, to do all over again, what I did with the 390 for my highboy, I'd say "buy the Edel heads". Much easier. And much cooler looking
Since aluminum helps with detonation then a higher compression could be used with a lower octane, say 9.5 and 87 octane? Am I on the right page here?
