Rotor Lateral Runout?
I have a massive amount of lateral runout on my rotors both sides and I have cleaned all surfaces. It’s a DRW so I have the hub extenders too. The weird thing is I have less in the extender than the rotor.
Any thoughts on what is causing so much lateral runout? You would think I have heavy debris between the rotor and hub but I cleaned them real well with an abrasive paint/rust stripper. Every surface is very clean. The wheel hubs spin nice and smooth too. My rotors were just warped and I had them turned so maybe it really threw it out of wack?
thanks
thanks
The following users liked this post:
I guess I'm not clear on what you are describing, but sounds like it could be wheels, tires, or bearings. I am not familiar with duallies so don't know if there are other components at play.
Are you getting vibration at speed or pulsing brake pedal when braking?
I almost always replace pads and rotors together.
When I turned the warped rotors I put new pads on also.
Yes I’ve got multiple vibrations right now in driveline (I’ve narrowed it down with help on this forum to the bushing in the transfer case tail housing), and in the front both at speeds and a pulsing brake pedal.
I can feel the pulsing brake pedal more at lower speeds. Vibrations don’t always get worse with more speed and seems almost intermittent which is why I thought maybe hubs. They’re only a couple years old and roughly 30k miles but my thought was that maybe certain angle in the road or crown causes the hub to “correct” itself and then the vibration goes away temporarily. I don’t think anything else up front could cause the intermittent vibration regardless of speed besides that? But I really don’t know..
Yeah, you'll get a bouncing brake pedal at low speeds and a low frequency shudder that follows wheel speed at highway speeds if you don't get all of that nice and flat. That issue right there gave me the most headaches on brake jobs. Learned to choose carefully which brands to purchase and install for the customers.
In my experience once a rotor is warped it's time for new ones, I've had warped rotors turned and they never worked out.
As for the vibrations hows your tires and wheels? I've had tires break a cord and wasn't visible till I had them balance on the balance machine then you could see them move up and down.
since I’ve been tracking the front end vibration, I’ve installed new tie rod ends (1 was bad), spicer ball joints (1 bad), brand new tires mounted and balanced (old ones were cupped), and I have new calipers nice and greased. Gear box is a year old, wheel hubs a couple years, and I aligned it. I don’t think there’s any other bases to cover at this point besides these rotors. I do have a partially seized u joint in the front drivers side wheel but the lockouts are manual lockouts and are free.
Since your truck is 4x4 I highly recommend replacing the track bar or at least the bushing if possible if not already, my trucks track bar was shot and allowed the suspension to do what ever it wanted on ruts on the road, and even caused some major clanking when turning or hitting minor bumps.
