351 id need help
351 id need help
from what i know i have a 351 c the numbers i can get off are on the block is D2AE-CA and above that is 2L14 in the head is 2L4 and on the valve cover is D3AE-9C485-AGA can you please help and with the heads i understand there are two types the 2v and 4v? the driverside head has a 2 and a 22 on the intake side not the exhaust so can you please help?
D2AE-CA is probably the most popular block casting, it got built as 2V, 4V, 2 bolt mains and 4 bolt mains... in other words it could be anything until you visually determine what it is.
2L14 is the cast date, Nov 14 1972... so it's a 1973 model year production block. no way it came with D1ZE-DA heads
2L4 would be a cast date of Nov 4, 1972, also 1973 model year production. this is under the valvecover? are both heads 2L4 or is the other head different? most heads have a number(2, 4 or M) in the top corners at the edges of the valve covers, is this where you're seeing the '2's? if so they are 2V heads.
D3AE-9C485-AGA, that's on the valvecover sticker?
what intake manifold is on the engine, if there is one? factory cast iron, 2bbl or 4bbl? aftermarket?
here's a pic of the different ports, 4V, 2V & Windsor
2V exhaust ports are oval, slightly smaller than the intake ports. 4V exhaust ports are almost square, and the manifold has a scallop for clearance for the top bolt. the 2V X-manifold doesn't need the clearance around the top bolt because the port is smaller
you have the heads off the block? 2V valve sizes are 2.04" & 1.65", 4V valves are 2.19 & 1.71", Boss 302 had a 2.25" intake. it's possible, 4V valves get installed into 2V heads for various reasons but the 2V valves aren't small either
what are the casting codes on the heads, on the underside of the intake port runners?
these are stock 2V valves
asmith6
24
08-21-2016 04:27 AM
Mudshovel_009
03-10-2015 12:22 AM
raerjim
04-25-2010 05:06 PM
keisha9
12-22-2006 08:02 AM
