351 Heads
Old Aug 2, 2007 | 09:34 PM
Chuck_Sloggett's Avatar
Chuck_Sloggett
351 Heads
I have 2 351 heads one with casting C5AE and the other D5AE. Both have 1.84 intake valves. Will someone identify these for me? What Year and application were they? Thanks -- Chuck
Old Aug 3, 2007 | 01:07 AM
Beanscoot's Avatar
Beanscoot
The C5AE number means that the original application was in 1965 model year, and since the 351W came out in 1969 this is not a 351W head.
The D5AE number means that the original application was in 1975 model year. You need to include the complete casting number for further identification.
Old Aug 3, 2007 | 05:24 AM
HemiEater's Avatar
HemiEater
and neither has 1.85 valves...only the C9 and D0 had them
Old Aug 3, 2007 | 06:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5AE = Cylinder Head Casting Number
C5AE cyl head casting number. Intake valve = 1.84" >> C9OZ-6507-J >> replaced by >> D2AZ-6507-A (note: The intake valve is a FoMoCo updated part number. I could not find the original 1965 part number it replaced.) >> The matching exhaust valve should be 1.54" <<
Cylinder Head: C5OZ-6049-A >> replaced by C5OZ-6049-B >> replaced by C7ZZ-6049-C = 289 Special (HiPo) 1965/67.
Info source: 1965/72 Ford Passenger Car Parts Catalog / Section 60.4 = 289 & 289 Special Engine Parts / Page 13.
Note: The 1968/70 302 HiPo cylinder head used the same 1.84" intake valve as the 289 HiPo. The same valve was also used on 1969/72 351W's. C9OZ-6507-J >> replaced by >> D2AZ-6507-A.
Old Aug 3, 2007 | 06:42 AM
NumberDummy
D5AE = Cyl Head Casting Number
Only one V8 cylinder head circa 1975 used a 1.84" intake valve.
Cylinder Head: D7OZ-6049-B .. 351W ~ Used on all 1975/78 Ford passenger cars; 1975/78 E150/350's (Econoline).
Note: D7OZ-6049-B is a 1977 Ford updated part number for the 1975 cyl head.
Old Aug 7, 2007 | 11:10 PM
Chuck_Sloggett
OK - I got the wrong information, both heads are D5AE and have 1.78 intake valves, both have 351 cast in to them, one has 6D29 and the other has 6E28. I would like to know what CC these have and what was the application. Thanks -- Chuck
Old Aug 8, 2007 | 01:27 AM
petes79f150's Avatar
petes79f150
I'm just guessing, but I think '75 Galaxie, 60.4cc? Bill, I found reference to the D5TE (truck) head with the 1.84 intake with a 60.4cc chamber.? And the only D5 head I saw with a 1.78 intake was a 302.?? Yikes I'm lost again.
Chuck: https://www.ford-trucks.com/forums/3...6-10-06-a.html
Pete
cnherrick
New Member Introductions
Sep 21, 2015 01:37 PM
verch101
Mar 8, 2011 04:03 PM
Vinford
Garage & Workshop
16
Dec 26, 2008 01:57 AM
chuck7300
Sep 6, 2008 02:38 PM
csuteau
Aug 19, 2008 04:24 PM
