1976 Ford Highboy
Old 05-19-2010, 06:38 AM
dragracer1956's Avatar
dragracer1956
dragracer1956 is offline
1976 Ford Highboy
My truck has a Dana44 in front with factory power assist. My question is I would like to install a Dana 60 and retain my power assist, is this feasible or am i wasting time and where would be the best place to look for an axle,or do i have to build one.Thanks Craig
Old 05-19-2010, 10:46 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
your in the wrong forum for this question. this is for engine swap questions.
that power assist sucks. ive owened a couple of those fords and it was there worst design. if you swap over to a D60 i suggest you also swap over to a 78-79 F250/F350 power steering box and go with a hi steer setup.
Old 05-20-2010, 08:49 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thread moved to the 73-79 truck forum.
Old 05-20-2010, 10:25 AM
75F350's Avatar
75F350
75F350 is offline
Crew caba nd some forestry trucks used low pinion dana 60's and power assist. What I am getting at is that even if you upgrade to a high pinion dana 60 and wish to keep this style steering you can find a bracket that will work.
Other wise you are going to have to modify the existing bracket to fit around the larger axle tube. Some cutting and welding will be required but this has been done.
i too agree that this steering is problematic and not worth the time to install.
Integral power steering is a far better solution.
Old 05-20-2010, 11:25 AM
30over's Avatar
30over
30over is offline
IMO I would spend the time and money for a better steering system. I did the 78 79 F250 4x4 steering upgrade with a Borgeson steering shaft on my highboy and I'm really glad I did.
There is other steering setups I'm sure by now for the highboy. Unless your really into heavy 4 wheeling or the price is inviting for the D60, I'd spend the money else where.
Old 05-20-2010, 11:44 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I too did the 78/79 steering box upgrade to my '74 highboy with the ram-style steering. BIG improvement.
Old 05-20-2010, 07:05 PM
dragracer1956
Thanks for the reply,My truck is 90% restored to factory ,i just thought the 60 series front axle would complment the rear.Theonly other thing i did to the truck that is not factory is i installed a406 tri-power engine.Again thanks for the reply Craig
Craigwell
17
08-24-2012 11:46 AM
50man
1997-2006 Expedition & Navigator
07-03-2012 12:42 AM
alaskaforby4
09-11-2009 02:27 PM
catbird7
07-28-2003 06:55 PM
SteveSS
10-07-2002 11:22 AM
Quick Reply: 1976 Ford Highboy
