oil cooler o-rings?
oil cooler o-rings?
I haven't posted for a long time - it would be great if anyone could answer this. My question is are the oil cooler o-rings a special size or something? The gaskets are only 6 bucks at NAPA, but they don't have a size for the o-rings - a kit is $65-100 ... why the price difference??? Thanks! DT
the o-rings are freaking thick. way thicker than any other o-ring i have ever seen, but that doesn't mean they are special. i would guess they are special though..
Typically the same as other o-ring type stuff. Expect failure somewhere betwen 1 and 1,000,000 miles depending on weather. Colder winters appear to shorten the life span a little. I've got 348,000 miles on my stock oil cooler. I'd say fix it when it leaks.
I know the book says not to use sealant on that front gasket but you should. I've rebuilt a lot of them and the only time I didn't use sealant it leaked. Be sure to use the RIGHT torque wrench and torque specs. Remember to be accurate with a torque wrench you can't use an extension and the torque needs to be in the middle 50% of the torque wrenches range. In other words a 20-250 ft pound wrench is not accurate doing 250 foot pounds but it is if you are doing 125. And also to be accurate the bolt threads need to be clean and lubed.
If you don't have a shop press a big ratchet strap helps a ton putting the headers back on too!
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
07-21-2019 01:40 PM
Firefighter 1406
21
11-27-2014 08:02 AM
