Duplicolor vs Rustoleum
Old 05-10-2010, 06:42 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
we did this comparison a few months ago, but ill post it up for everyone.
the piece is a metal cover off of a dirtbike. it was sandblasted and washed. an even coat of rustoleum primer. hit the one corner with rustoleum and let it dry. then hit the other corner with duplicolor and let it dry. you can clearly see the difference.
(the duplicolor is the shiny stuff.)
Old 05-10-2010, 08:50 PM
2002sport's Avatar
2002sport
2002sport is offline
I never had luck with Rustoleum paint lasting more then a few months, then it seems to fade.
Old 05-11-2010, 05:05 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,108 Likes on 2,168 Posts
rustoleum does not have UV blockers in it, that is why it fades.
but it does have rust inhibitors in it. that is why it is used in places where shine is not important.
duplicolor has UV blockers, but no rust inhibitors. it is made for automotive paint spot repair.that is why it keeps it's shine.
2 different paint blends for 2 different applications
Old 05-11-2010, 05:39 AM
93 mix 'n match
i understand that, but this is just to show people there is a difference.
Old 05-11-2010, 04:47 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
I just bought a can of Duplicolor Oxford white to color match my new stone deflector for the front of my truck. I gotta say I'm not impressed with it. It's spray pattern is vertical so it didn't cover very well, and it dripped on the piece as I was painting.
I ended up using Krylon white, and it matches my color better than the Oxford white. I was told this is the right color according to the paint color code on the truck.
I may try using the Duplicolor as the 3rd color coat before I put 2 coats of clear on.
Old 05-11-2010, 07:30 PM
tjc transport
i ain't rite
ok. i wasn't sure if you knew that or not.
Old 05-11-2010, 07:40 PM
93 mix 'n match
i didnt know that exactly, but i knew there was a chemical difference. i figured this would save some people some time. instead of buying rustoleum for touch up work.
Old 05-11-2010, 08:58 PM
2002sport's Avatar
2002sport
Okay, that makes sense. What would happen if you put a coat or two of Duplicolor over a couple coast of Rustoleum?
Old 05-11-2010, 09:22 PM
Nitramjr's Avatar
Nitramjr
Nitramjr is offline
You would either get a shiny coat of paint that didn't rust or with my luck, a dull coat of paint that rusted in no time.
Old 05-12-2010, 05:16 AM
tjc transport
i ain't rite
Ray, you got the same luck as i do,aint ya
i did a small job with rustoleum and then sprayed uv blocking clear coat over it last year. so it is still holding it's shine.
i am going to try it large scale this summer on a truck and see how it holds up over time.
Old 05-16-2010, 08:40 PM
Aftrmidnite's Avatar
Aftrmidnite
Aftrmidnite is offline
At work they use McCormick Inter-lock paint, on all the outside stuff. A couple times a year they come in on the weekends and spray paint all new work with a clear anti Graffiti paint. I think it's by Duron. Doesn't fade and is extremely durable.
BTW Are you sure you didn't get a can of Rustoleum Hammer Finish?
Old 05-16-2010, 08:50 PM
93 mix 'n match
nope. just regular rustoleum paint.
Old 08-04-2012, 04:08 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
Originally Posted by *2fords*
I just bought a can of Duplicolor Oxford white to color match my new stone deflector for the front of my truck. I gotta say I'm not impressed with it. I ended up using Krylon white, and it matches my color better than the Oxford white. I was told this is the right color according to the paint color code on the truck.
I realize this is an old post but the Duplicolor Oxford White matching problem keeps happening year after year.
I too have an Oxford White Ford (Aerostar) and I tried Duplicolor's Oxford White; No match, not even close. Then I tried Krylon Fusion Gloss White and the match was good.
BUT I discovered there's an even better match for Ford and GM Oxford White:
AeroTech RUST RX #101 Gloss White made by Aerotech Products
try it! you'll be amazed.
forget Duplicolor for any of your car paint needs, their "perfect match" advertising is false and irresponsible advertising, eventually they'll go out of business for fooling consumers. If it was a problem with ONLY the Oxford White it would be one thing, but the problem is with EVERY COLOR, nothing matches, even with new cars!
Old 08-04-2012, 04:22 PM
tjc transport
i ain't rite
really?? we use it all the time for small touch-ups at the body shop. never had a problem with a miss match in over 25 years of use. .
Old 08-04-2012, 05:40 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
you can't possibly have been using Duplicolor paints for over 25 years because the Duplicolor company was established in 1996.
2012 - 1996 = 16
Quick Reply: Duplicolor vs Rustoleum
