Is this an odd oil leak?
I noticed today that the valve cover bolt pocket near the oil fill tube was full of oil and the bolt is tight. Is it common for oil to come up through there? I didn't notice it two weeks ago.
Everything else on the right side is dry but I have noticed a few damp spots by the bolts on the left valve cover. The 5.4 has just over 100k on it.
RTV both sides too. Don't just rely on the gasket. Coat the cover side then install the gasket and let it cure a bit. Spread an even coat on the head side then install the cover and run the bolts down till they bump. Let it cure for as little while then go ahead and run the bolts/screws down all the way. This kinda helps seal them better.
That’s a negative on spilling since that was over a thousand miles ago. I was under the hood two weekends ago because I was changing my ball joints and had to disconnect the ABS leads. I always give things a look over when I have the hood up also.
I’m not to keen on using RTV but I’ll think about it. Anybody else have thoughts on using RTV?
newrider3
20
11-30-2020 01:47 PM
