Bleepin' beepin'
Old 05-10-2010, 10:53 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Bleepin' beepin'
I have a 95 B2300, and everytime I start it up, I get a series of 5 beeps then a short pause and it repeats. It goes thru 5 cycles of 5 beeps.
The beeping is coming from behind the passenger side kick panel, and is quite annoying. After driving the truck for about 45 minutes, it repeats this 5 cycles of 5 loud beeps. What is it?
Old 05-10-2010, 01:10 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Sounds like a backup warning for a burned out idiot light. Most likely air bags
Are all the idiot lights working at KOEO (key on/engine off)?
powersmoked's Avatar
powersmoked
powersmoked is offline
I think it is you airbags srs?. is the light on for the system. maybe the bulb is blown? check fuses? I think if the light is working there is some way to read codes from the light flashing but not sure........
Old 05-10-2010, 01:36 PM
Rogue_Wulff
No SRS/Air bag light with key on/engine off. No owners manual to tell me which fuse/fuses to check out of the 50 bazillion either. Ok, so I am exagerrating a little.....
I first though it was related to the seat belt, as the DS seat belt was cut by a PO, but I replaced it a couple days ago and the bleeping beeping didn't go away.
Any ideas on which fuses/relays to check first? Getting cluster out to check the bulb is a lot more complex than checking fuses. I've done had it out to replace all the dash lights......
Old 03-28-2011, 03:29 PM
Rogue_Wulff
Yepperz, turned out to be a burned out air bag light. Now, just need to find out what a 3-5 blink code means.....
Old 03-29-2011, 07:03 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
Her is a link on airbag codes. It just lists the codes. Doesn't give any info on how to troubleshoot them.
http://www.airbagsolutions.com/docs/codes/f/a.pdf
Old 03-29-2011, 10:33 AM
Rogue_Wulff
Turns out a code 35 is passenger air bag related, and this truck doesn't have a passenger airbag. Suspect the airbag simulator is unplugged or bad.
98FordTruck
1997 - 2003 F150
04-24-2020 07:02 AM
et_miller_87
82
11-30-2014 07:17 PM
abriel68
1999 to 2016 Super Duty
11-05-2012 08:53 PM
pabear89
Escape & Escape Hybrid
08-24-2011 12:57 PM
John7894
01-04-2005 01:33 PM
Quick Reply: Bleepin' beepin'
