1997 E150 Need location of computer (High Top Conversion Van)
Transmission problems in 2, one with the 300 I-6 has 350,000 miles, check engine light is on, short on power, one needs the idler pulley replaced, and he needs to install batteries in one of the 90 models to drive it. When he finds a wheelchair rigged van cheap, he buys it, wheelchair lifts are expensive.
Doesn't anyone have any idea where I can locate the computer on my van? I have done everything else I have been told to do to get this thing running kike it should, Changing out the computer is the last thing I can dp. It runs like it is only running on 7 cylinders. It has no power when I accelerate and kinda sputters. I have cleaned the injectors, put on new catalytic converters, new power packs, new EGR valve & sensor, new plugs & wires, fuel pump checked and new map sensor ect. So, as you can see I am running out of things to try AND MONEY. So, PLEASE HELP any way you can.
Thanks A Million,
SCBeachBum
P.S.
If you have any idea other than the computer all information is Greatly Appreciated:-)
Thanks A Million,
SCBeachBum
P.S.
Its the case of the moving computer... jeezus what a crazy process?. Different years have different locations,different transmissions,different intakes!. I have a 96 E350 7.3 which has been kicking my *** trying to fix this stumbling idle and erratic running even driving. Ive done "everything" the guys threads above mine has done and nothing (but less money and even less patience). Im thinking coils and or a PCM. To make this trickier ,its a 31ft RV so its possible the RV company relocated a whole bunch of stuff to add even more circuitry than these things already have. Anybody out there that can help with coil replacement details and PCM location?. I found a 2nd solenoid ( after tons of head scratching) under the drivers side battery tray. Entire grill assembly came off,headlights,blinkers etc. I can do this with my eyes closed now. Thanks for any help.Jordan Grant,Norwalk Ct
I didn't see any testing or diagnostic work on your list. Have you tried any of that?
Or just parts swapping?
1OldFordMan
18
12-13-2017 08:27 PM
mytimeistoday
09-26-2016 11:29 AM
84chateau
05-18-2016 09:52 AM
mopar440
03-31-2016 01:42 AM
I am Murphy law
1999 to 2016 Super Duty
03-21-2016 06:31 PM
