1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How to clean trailer plug terminals???
Old 05-05-2010, 07:21 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
Robs06SuperDuty is offline
I kinda need help quick, so the other weekend I hooked up to my buddys landscaping trailer, everything was fine until I plugged in the harness, No Lights...no big deal cuz it wasnt much of a drive, but I gotta haul a boat tomrrow a little ways and Id like to be legal lol.
I need some suggestions on cleaning my trailer plugs. What is the best way to clean the terminals on the small 4 prong? The big plug is fine, just a little dirt inside the cover, but im still going to clean the contacts and put di-electric grease on them.
Thanks in advance.
Old 05-05-2010, 07:27 PM
dmpruss's Avatar
dmpruss
dmpruss is offline
My advice is to forget trying to use the 4 prong and get an adaptor for the big one. Much easier to keep the big on reliable based on my own experience. The big one also latches in better.
Old 05-05-2010, 07:37 PM
Robs06SuperDuty
thought about gettin an adapter but id like to try and get my stock 4 prong working first before saying eff it.
worse case scenario ill buy an adapter.
Old 05-05-2010, 08:11 PM
senix's Avatar
senix
senix is offline
Received 1,443 Likes on 1,032 Posts
well i have used pipe cleaners and que tips in a hurry it that helps, then grease it up.
Old 05-05-2010, 08:17 PM
Robs06SuperDuty
Senix: did you use any kind of solvent?
btw: thats a big *****ing camper!
I think I might have a small wire brush, maybe even a .22 brass cleaning brush would work, and possibly some electric cleaner.
Old 05-05-2010, 08:23 PM
senix's Avatar
senix
senix is offline
wd 40..baby bottle brush may help...yeah that is 14K and 40' of 5th wheel there.
Old 05-05-2010, 08:58 PM
dmpruss's Avatar
dmpruss
dmpruss is offline
You need something that will clean the copper corrosion. I use bar keepers friend cleaner. Another thing that works well is jewlery cleaner.
Old 05-06-2010, 04:48 PM
BareBones's Avatar
BareBones
BareBones is offline
I'm just guessing, but what about murietic acid or possibly vinegar?
Old 05-06-2010, 07:44 PM
bunklash's Avatar
bunklash
bunklash is offline
You can buy spray cans of electrical contact cleaner which may help. I'd prefer getting in there with a brush or narrow abrasive to get it clean, then dielectric grease to keep it from corroding again. Good luck.
Old 05-06-2010, 07:46 PM
senix's Avatar
senix
senix is offline
I don't think I would ever put muietic acid on there. that stuff eats thru everything.
Old 05-07-2010, 10:20 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Don't use this,we used it to clean the drums on our cement mixers,it tears through stuck on, dried out concrete.Not good for electrical connections.
Old 05-07-2010, 10:35 AM
ontariofarmer's Avatar
ontariofarmer
ontariofarmer is offline
If you use muratic acid the plug will be gone tomorrow
A small wire brush works GREAT. Then spray with contact cleaner
Old 07-16-2013, 12:23 PM
NeonIsMyColor's Avatar
NeonIsMyColor
NeonIsMyColor is offline
Thanks in advance.
Clean Trailer Plug - Home
Old 07-16-2013, 12:33 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
A brush that fits those small openings has been available at many RV dealerships for years and maybe some automotive stores. Not sure about the automotive stores. Not much demand for it, so it many be hard to find. I have one on my truck, but seldom use it. If an RV dealer doesn't have it, they can easily get you one as they are in the catalogs.
ShortBed'86
04-25-2017 07:01 PM
VT tree grower
04-07-2016 09:20 AM
snaponprofile
06-01-2013 07:49 PM
jdhudall
1997 - 2003 F150
04-01-2012 11:13 PM
MDSuperDuty
04-27-2011 06:23 PM
Quick Reply: How to clean trailer plug terminals???
