Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-02-2010, 11:08 AM
recluse recluse is offline
Garage is empty, add now
recluse is starting off with a positive reputation.
Off set tires.
I have 3'' Ready Lift on my 2007 Expedition with 305/70R17 BF Goodrich tires.
The stock rims come with +44mm off set. I want to replace stock rims with a different off set.
I would like to go with 0mm off set, 2nd option would be +22mm. Like a man I think bigger is better.
Has anyone installed off set rims? I know some mods have to be done to the front plastic bumper to prevent rubbing.
Thnx.
  #2 (permalink)
Old 05-02-2010, 01:17 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
look at the 04-08 F-150 setups...and the 09+ setups
we have the exact same front suspension as them. Just be careful with going too far. You might rub the frame
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 05-04-2010, 05:35 PM
I've found what I want
Pro Comp Series 7028 Cast-Blast Wheels - Xtreme Alloy Cast Wheels, Pro Comp Cast Wheels
The rims have 0 mm offset.
Can anyone advise how bad is splashing with the wheels sticking out by almost 2''?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
