Off set tires.
I have 3'' Ready Lift on my 2007 Expedition with 305/70R17 BF Goodrich tires.
The stock rims come with +44mm off set. I want to replace stock rims with a different off set. I would like to go with 0mm off set, 2nd option would be +22mm. Like a man I think bigger is better. Has anyone installed off set rims? I know some mods have to be done to the front plastic bumper to prevent rubbing. Thnx. |
look at the 04-08 F-150 setups...and the 09+ setups
we have the exact same front suspension as them. Just be careful with going too far. You might rub the frame |
I've found what I want
Pro Comp Series 7028 Cast-Blast Wheels - Xtreme Alloy Cast Wheels, Pro Comp Cast Wheels The rims have 0 mm offset. Can anyone advise how bad is splashing with the wheels sticking out by almost 2''? |
