quick cold start check engine light
It is a California truck built January 1997.
Check engine light comes on a few seconds after the ignition key is on whether the engine is running or not.
How much does a scanner cost ... one that will reset the check engine light?
I live in Los Angeles and most here want money to reset the code.
Many on here have a Auto Entegrity system that you load on your laptop.It will read all kinds of things on your truck.Clay(Riffraff) sells them.I do not know what they go for now.Surely there is a member near you that has a programmer or AE that will read the code and clear it for you.You may need to start a new thread asking the California crew if anyone is close.
Thank you !
Yep ... cigarette lighter does not work.
Where is the fuse ... since all the fuses in the engine compartment behind the air filter are all intact.
KDmike
04-24-2017 08:58 AM
coxhaus
08-02-2016 04:02 PM
