multi function switch
Old 04-27-2010, 10:34 AM
redman84's Avatar
redman84
redman84 is offline
Just curious. Anybody ever changed out the multi-function switch(blinker, wiper switch)? Mine's broke for years now and I'm getting tired of turning it off. Plus I forget a lot. How hard is it?
Old 04-27-2010, 10:43 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
Follow this link (even though it says injectors)
Performance Injectors for 7.3L Ford Power Strokes
Old 04-27-2010, 11:41 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
I have this saved in my PC maybe also helps you.
Removal
  1. Disconnect battery ground cable (14301).
  2. <ORemove the steering column shroud (3530). <O
  3. Remove two self-tapping screws that attach the multi-function switch (13K359) to the steering column tube casting. Disengage multi-function switch from casting. <O
  4. Disconnect the two electrical connectors, using caution not to damage the locking tabs. Do not damage PRNDL cable.
Installation <O</O
  1. Install the two switch electrical connectors to full engagement. The wiring for the switch is to be routed under the PRNDL cable. <O</O
  1. Align the mounting holes on multi-function switch with the holes in the steering column tube casting. Install two self-tapping screws making sure to start the screws in the previously tapped holes. Tighten to 2-3 Nm (18-27 lb-in). <O</O
  1. For automatic transmission (7003), verify that the PRNDL adjustment is correct. <O</O
  1. Install the steering column shroud. <O</O
  1. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
    Connect the battery ground cable. <O</O
Check the steering column tube (3514) for proper operation.
Old 04-27-2010, 11:55 AM
redman84's Avatar
redman84
redman84 is offline
seems easy enough. thanks guys. gonna get on that
Keith Free
1978 - 1996 Big Bronco
08-31-2016 06:34 PM
PStruwing
15
11-09-2015 06:17 PM
Phil Ayres
1999 to 2016 Super Duty
10-07-2015 05:44 AM
Ford'05HG
1997-2006 Expedition & Navigator
05-31-2014 12:44 AM
Phanman43
03-04-2014 07:08 PM
Quick Reply: multi function switch
