87 6.9 4x4 t19 to zf5 swap
Picked up the transmission and transfer case out of a 93 non turbo 4x4 today. Want to get started on the swap asap. I read on here that the flywheel off my 6.9 will work I just have to get a new pressure plate, clutch disc and throwout bearing to go on the zf and match the 11in solid flywheel. Is that true?
There was a member that did this swap, and posted the numbers of the clutch and pressure plate that he used. He went by Cheeperjeeper I beleive. When I did this conversion to my 85, I used a single mass flywheel conversion for a 7.3 IDI from NAPA, as the numbers that he posted wouldn't cross over to NAPA ones, and they are the only after market parts house in town. I found the 6.9 pressure plate mounted to the flywheel with 6 bolts and the 7.3 conversion mounted with 8 bolts, so the 7.3 clutch and presure plate would not mount to the 6.9 flywheel.
VaFordman26
20
07-29-2015 04:09 PM
bigblockford_390
02-21-2010 12:49 PM
