why do head gaskets block water ports on 302
Old 04-25-2010, 10:59 AM
1bad67sbf's Avatar
1bad67sbf
1bad67sbf is offline
i just put my e street heads on and noticed that the fel pro gaskets only have the rear water jackets open. is this to force water thru the smaller ports near the cylinders
Old 04-25-2010, 10:28 PM
393STROKER's Avatar
393STROKER
393STROKER is offline
I`m pretty sure you need to trim any of the gasket material that would restrict the flow of water to the heads.The gaskets can be used on different heads with a different port shape. It should mention that in the instructions.The blue sealent ridge should outline the ports. Thats if I`m following what your saying.
Old 04-26-2010, 06:16 AM
1bad67sbf's Avatar
1bad67sbf
you do trim them for the intake gasket but not the head gasket unless your running a 351w i think
Pond
03-19-2021 07:29 PM
mgregoris
Modular V8 (4.6L, 5.4L)
07-14-2015 08:23 AM
schweinhaus
06-06-2015 04:05 AM
skidoorulz
03-31-2015 03:29 PM
fsvahn
02-26-2012 08:10 PM
Quick Reply: why do head gaskets block water ports on 302
