intake manifold water ports missing?
I have an '86 F250 automatic with a stock carburated 460 engine. I am in the process of replacing my intake manifold gasket and I noticed that the rear water ports on the heads are blocked because there are no corresponding holes on the intake manifold.
My old gasket set also had no holes for the rear water ports, but the new one I picked up does.
Can anyone shed some some light on this for me? Do I have the correct intake manifold? Will it harm anything to have the rear ports blocked?
Thanks,
Jason
Thanks,
Jason
The rear crossover is ok to be missing on a aluminum intake manifold. Look at it this way, if you had both crossovers you would heat the manifold and it would creep into the carb boiling the gas. You can use the intake gasket you have with no problems just remember to use rtv around the water and intake ports.
Thanks for the advice.
Incidently, my intake manifold is way too heavy to be aluminum, it must be cast iron. Additionally, the new gasket set consists of a pair of metal gaskets riveted to each side of the valley pan. Would this affect the use of RTV around the water ports?
Jason
Jason
Oh, I forgot, there is also a "number wheel" in the casting like they use for manufacture dates on things, but there are only four numbers on the wheel (9758) and the pointer points to the 8.
There is also a stray number 12 stamped to the right of the firing order. I don'y know if these two things mean anything.
How did you seal it?
Pond,
"Additionally, the new gasket set consists of a pair of metal gaskets riveted to each side of the valley pan. Would this affect the use of RTV around the water ports?" I am starting the same project.How did you seal pan/head and pan to manifold? What about the little nubs from the riveting- problem? Did you RTV beneath the pan and then the manifold gasket between manifold and pan? Thank you.
The rivets won't hit. Lose the cork or rubber ends seals. I used a bead of rtv black under the valley pan on the ends rails only. Same place on top and just a little around the water ports only. That gaskets is actually rubber covered so it needs no sealer around the ports. Fel Pro advised me against it and mine has been fine for 10,000 miles so far.
michbol
11-14-2011 01:25 PM
atomicjoe23
08-15-2010 09:13 PM
Falcon Guy
04-07-2009 03:51 PM
asmith6
11-30-2007 09:35 PM
76 F250 4X4
09-21-2004 06:50 AM
