1992 F 250 clutch spring problem
ive got a problem with the clutch pedal spring on my 92 F 250. The spring is actually used to make the pedal go down easier, but on my truck, the spring is broken off. its broken off where it attaches to the metal bracket under the dashboard, this bracket also serves as the mounting bracket for the brake pedal. my question is, what is this bracket called, i want to call a junk yard or a parts store and order a new one , but dont know how to describe it.
<!-- / message --><!-- sig -->__________________
My dad had the same problem on his '92 several years ago. We got a new one (revised design) from the local dealer for right around $100, best I can remember. It came with new brake and clutch pedals, rubber pedal pads, shaft bushings, spring, and cross shaft lever for the clutch master cylinder. Ed from y2kfordparts.com is a member here (partsguyed, if I remember correctly); he can probably help you find the correct assembly.
RollinK
01-03-2017 05:06 PM
smithriver101
18
06-14-2015 08:55 PM
bailegb
05-19-2010 06:02 PM
llee
10-10-2008 02:27 PM
389sixpack
1999 to 2016 Super Duty
05-29-2007 01:30 PM
