Who needs a speedometer anyway
Speedo done gone dead on me. It was reading a little off. Then I got a speeding ticket and apparently it was reading 13mph off. Then it was WAY wavy. Then it went dead. Zip, zang, nada, nothing.
Pulled the nylon speedo gear out, 18 tooth yeller color. The gear teeth had a valley shape to them, so i went to buy a new one. What? Ford doesn't make them anymore! Cool. So I went to the junk yard. Pulled about 20 of them before I finally found an 18 tooth. Threw it in there. No difference.
Chucked my drill onto transfer case end of the speedo cable and HEY! It's working great!
So I guess it's the drive gear inside the transfer case. Thought you guys said these transfer cases were bullet proof.
on
Stick you finger in the hole and see if the drive gear has the same concave shape, if it does ... replace them both as a set.
Take your tire size, rear gear ratio, transmission info to Ford and they'll set you right up with a matched set.
And not as costly as one would think!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
About 1/2 way down the page is the Ford gear section.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Not sure, but I believe the transfer case drive gear will come out after you remove the yoke and output seal.
Jason
Jason
Heres a nice thread showing a full tear down where you can see what I mean:
transfer case teardown
That is the photo album of my tear down to figure out why my transfer case wouldnt stay in gear. Damn shift fork ate the big one. Any questions with the BW 1356, let me know, ive done it all! Took it down to scraps and built a new one from a donor and mine. I have the other one all ready to go, just started ordering it piece by piece and now it is completely new. Aside from the housings, which my dad is coating as we speak. Black chrome! Should be sweet!
EDIT... the TC's are solid as a rock, it is poor maintenance that kills them. Mine died because of a leak that i didnt pay attention to and when i pulled it apart, it was nearly dry, bad on me but when they are cared for properly, they will outlast a transmission and engine combo any day. Well that is unless you are doing sled pulls and craziness. Wish they had a gear mod you could install, kind of like the timing gear to swap the timing chain. Either way ***** happens, do the best you can.
Nope, have to take the output housing off to get to it. Its held in place by a ball bearing on one end, and a metal clip on the other. I just tore open a transfer case (actually two..) and its pretty easy. Actually, you could swap the gear while its still installed, just drop the driveshaft, pull off the housing, swap the gear, clean everything up nice and put it back together.
Jason
on
Nope, I have not read the posted threads yet, I will ASAP!
The exploded view I looked at (at Ford) on the 13-45, shows a bearing on the inside of the drive gear and the yoke on the outside, thus pulling the yoke and the seal should allow the removal of the drive gear ... Is this incorrect????
I also know that the drive gear OD is smaller then the OD of the seal and it appears you can just pull the yoke, the seal, the drive gear, re-install new drive gear, new seal, yoke. Am I wrong on this assumption???
-Enjoy
fh : )_~
-Enjoy
fh : )_~
