gear shift won't move out of park
Old 04-17-2010, 04:30 PM
westernman's Avatar
westernman
westernman is offline
My gear shift on a 2003 ford f150 pu wouldn't come out of park. Changed brake light switch and checked fuses. There is one fuse that if I take it out. I can then shift. My windshield wipers quit working too. When from working to not working over night.
Old 04-17-2010, 07:40 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
what fuse is it?
Old 04-18-2010, 09:56 AM
westernman's Avatar
westernman
It is the 5amp #5 Shifter fuse
Old 04-18-2010, 10:20 AM
shorebird's Avatar
shorebird
shorebird is offline
Sounds like a cheap fix. Check the wiring in the column with emphasis where the tilt pivot is for the wiper problem.
Old 04-18-2010, 01:16 PM
westernman's Avatar
westernman
What ever stopped the shifter also has to do with wipers. They went out at same time.
Old 04-18-2010, 03:21 PM
westernman's Avatar
westernman
Ok back at it. Does anyone know what the interlock selonoid looks like and where it is located. I figure if I can find it, I can change it....
Old 04-18-2010, 08:14 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
See your owner's manual for shift interlock bypass instructions.
The wipers and shift interlock have nothing in common.
It is unlikely that the interlock is bad. Most likely, you have a fault related to the brake lamp switch circuit.
Old 04-19-2010, 07:01 AM
westernman's Avatar
westernman
I havr already changed the brake light switch. Didn't help. Already bypassed it so I can drive it. Want to fix it.....
Old 04-19-2010, 12:43 PM
westernman's Avatar
westernman
On the brake master cylinder is a two prong switch that screws into it. If it cracks in middle where you can't see it. Fluid will leak into the prongs and blow the #15 fuse which takes out window wipers and inside light and gear shifter will not come out of park. Replace switch and fuse and all will work. Part cost $20.00. I have been told several different things for this switch. I was told it was a hydrolic switch, A brake fluid switch and a switch that runs the cruise control. I think it is the switch that runs the cruise control and that they had a recall on. Any way truck works perfect and thanks for everyones help.
FordTruckChuck
1997 - 2003 F150
02-13-2016 04:21 PM
Bryan L.
10-05-2014 01:56 PM
Cobr17
05-01-2014 04:07 PM
bigblackbeauty
10-08-2013 10:10 PM
mavfan2977
1997 - 2003 F150
17
05-25-2008 08:14 PM
Quick Reply: gear shift won't move out of park
