1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No hot air from heater at idle?
Old 04-14-2010, 10:29 PM
RaftWW's Avatar
RaftWW
RaftWW is offline
Even after being fully warmed-up, the heater in my 2004 F350 6.0 doesn't put out any heat at idle. Within 5-10 seconds after driving down the road and getting the RPMs up, hot air finally comes out. Then after sitting at a light for a couple minutes, the heater blows cold air.
Any thoughts on the cause and the fix?
Thanks!
Old 04-14-2010, 10:46 PM
jlmotox's Avatar
jlmotox
jlmotox is offline
check your coolant level!
Old 04-15-2010, 02:30 AM
redford's Avatar
redford
redford is offline
Received 1,596 Likes on 933 Posts
Poosible causes that I have seen:
Coolant level (as mentioned)
Slipping belt
Failing water pump
Failing thermostat
Start with checking the coolant level and inspecting the serpentine belt. Those are the easiest to inspect.
Old 04-15-2010, 03:59 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Most likely: failing thermostat.
Did you check temp gauge and is it low when you don't get cold air.
If not, if you have automatic temperature control, the problem is in the valve that regulates coolant flow.
Old 04-15-2010, 08:48 AM
RaftWW's Avatar
RaftWW
RaftWW is offline
Coolant level (as mentioned) Just had it flushed and a new reservoir 2 months back
Slipping belt Doesn't look like it
Failing water pump Gawd, I hope not.
Failing thermostat That's what I was thinking...
Good input from all. Seems like I'll be fore-warned now when I take it to the mechanic.
Thanks!
Old 04-15-2010, 12:43 PM
bpounds's Avatar
bpounds
bpounds is offline
I'll put my money on the water pump. It is a common issue on the earlier 6.0 PSD.
Well, low coolant is very common too, but a quick glance eliminates that.
Old 12-21-2010, 11:20 AM
TFCO's Avatar
TFCO
TFCO is offline
Hey Guys does anyone know the outcome of this issue. (How was it repaired)
Old 12-21-2010, 02:46 PM
RaftWW's Avatar
RaftWW
RaftWW is offline
And the answer is...
Blown Head Gasket, Oil Cooler clogged with sand (left over from casting the block?) and low water levels!
New oil cooler, machined heads, upgraded head bolts (160 ft-lbs) and some other little things.
Grand Total: $5,300
Please don't say I got bent over the chair.
Old 12-21-2010, 02:47 PM
RaftWW's Avatar
RaftWW
RaftWW is offline
... and one small benefit
Fuel consumption improved up 2.5 mpg, a little consolation!
Old 12-21-2010, 03:16 PM
bunklash's Avatar
bunklash
bunklash is offline
Glad to hear a positive outcome. Better mileage means a lot these days. We're paying $3.18 a gallon here, bet it's even worse on your end of the world.
Old 12-21-2010, 06:18 PM
LaredoF350's Avatar
LaredoF350
LaredoF350 is offline
As I was scrolling through the thread I was going to post head gaskets - my 03 had all of the above stuff like yours done...
... on warranty though!
alitt
2009 - 2014 F150
03-03-2017 07:56 PM
BillJohnson
03-16-2016 12:32 AM
cooter05
02-26-2014 11:13 PM
reedytlr93
1997 - 2003 F150
15
01-08-2011 02:11 AM
R202INT
1983 - 2012 Ranger & B-Series
03-03-2010 07:49 PM
Quick Reply: No hot air from heater at idle?
